FOSI AUDIO LUNA3 Vinyl Turntable 33/45 RPM
New
The Fosi Audio Luna3 is a belt-driven turntable designed for analogue playback, featuring a 300mm acrylic platter and a stabilised rotation speed of 33 or 45 rpm with a variation of approximately 0.1% to maintain a consistent speed and minimise pitch fluctuations. It features an 8.6-inch aluminium tonearm paired with an Audio-Technica VM95E cartridge.
By buying this product you get 34 loyalty points
Reference : 21836
349,00 €tax incl.
290,83 € tax excl.
FOSI AUDIO LUNA3 Vinyl Turntable 33/45 RPM Audio-Technica VM95E 65dB
Photo of the Fosi Audio Luna 3
The Fosi Audio Luna3 is a belt-driven turntable designed for analogue playback, featuring a 300mm acrylic platter and a stabilised rotation speed of 33 or 45 rpm with a variation of approximately 0.1% to maintain a consistent speed and minimise pitch fluctuations. It features an 8.6-inch aluminium tonearm paired with an Audio-Technica VM95E cartridge, which allows for precise tracking whilst minimising distortion and mechanical noise, as indicated by a signal-to-noise ratio of approximately 65dB.
Designed for integration into a hi-fi system with an external phono preamplifier, it delivers a direct analogue signal via an RCA output, allowing the equalisation stage to be adjusted as required whilst maintaining a simple and scalable design. This approach is complemented by a standard 1/2" mounting that allows for cartridge replacement, whilst the automatic shut-off at the end of playback ensures safe use, positioning the Luna3 as a coherent foundation for a scalable home listening experience.
Fosi Audio Luna3: Playback architecture and mechanical stability
The Luna3 features a 300mm acrylic platter, whose inertia stabilises rotation at 33 and 45 rpm, thereby minimising pitch fluctuations and ensuring smooth playback. This base is paired with an 8.6-inch aluminium tonearm, whose controlled rigidity guides the pre-installed Audio-Technica VM95E cartridge, enabling precise tracking of the groove whilst keeping distortion to a minimum thanks to its elliptical profile.
This mechanical consistency, combined with a signal-to-noise ratio of approximately 65dB, demonstrates effective control of vibrations and background noise, ensuring stable sound reproduction without the need for any specific corrective measures.
Photo du vinyle et du bras de lecture du Fosi Audio Luna3
Photo du bras et de la cellule du Fosi Audio Luna3
Fosi Audio Luna3: System integration and scalability
The Luna3 delivers an analogue signal via its RCA output, featuring a design without a built-in preamplifier in order to maintain a direct, unprocessed signal, which means it must be paired with an external phono stage for amplification and integration with the rest of the system. This approach allows you to build a coherent audio system based on your chosen components, whilst maintaining a simple structure focused on analogue reproduction.
The system is completed by an automatic stop function at the end of playback, which halts rotation to minimise wear on the diamond stylus and the record, thereby ensuring safe use and seamless integration into a home hi-fi system.
Overview of the components of the Fosi Audio Luna3
Diagram of the components of the Fosi Audio Luna3
1High mass acrylicplatter
2Removable headshell
3Copper core motor
4High quality tonearm
5Servo motor control
Product typeTurntable
Type of turntableManual
Drive systemBy belt
Playback speeds33 and 45 rpm
CartridgeAudio-Technica VM95E
Diamond typeElliptical
Tone arm typeStraight
Tone arm materialAluminum
Tone arm length8,6 inch (218.5mm)
Cartridge output voltage4mV
Fréquency response20Hz-22kHz
Outputs1x RCA
1x 12V Trigger
Platter300mm
SNR65dB
Power supply12V 1500mA
Power consumption5W (Max)
Dimensions420x112x330mm
Weight3.5kg
Package1x Acrylic Platter
1x Headshell with Stylus
1x Platter Mat
1x Dust Cover
1x Counterweight
1x Plinth
1x 45 Adapter
1x Rubber Belt
1x 12V Power Adapter
Cartridge typeMM (Moving Magnet)
Rotation speed33 RPM
Rotation speed45 RPM
The Fosi Audio Luna3 is a belt-driven turntable designed for analogue playback, featuring a 300mm acrylic platter and a stabilised rotation speed...
