By buying this product you get 35 loyalty points
The Fosi Audio Luna3 is a belt-driven turntable designed for analogue playback, featuring a 300mm acrylic platter and a stabilised rotation speed of 33 or 45 rpm with a variation of approximately 0.1% to maintain a consistent speed and minimise pitch fluctuations. It features an 8.6-inch aluminium tonearm paired with an Audio-Technica VM95E cartridge, which allows for precise tracking whilst minimising distortion and mechanical noise, as indicated by a signal-to-noise ratio of approximately 65dB.
Designed for integration into a hi-fi system with an external phono preamplifier, it delivers a direct analogue signal via an RCA output, allowing the equalisation stage to be adjusted as required whilst maintaining a simple and scalable design. This approach is complemented by a standard 1/2" mounting that allows for cartridge replacement, whilst the automatic shut-off at the end of playback ensures safe use, positioning the Luna3 as a coherent foundation for a scalable home listening experience.
The Luna3 features a 300mm acrylic platter, whose inertia stabilises rotation at 33 and 45 rpm, thereby minimising pitch fluctuations and ensuring smooth playback. This base is paired with an 8.6-inch aluminium tonearm, whose controlled rigidity guides the pre-installed Audio-Technica VM95E cartridge, enabling precise tracking of the groove whilst keeping distortion to a minimum thanks to its elliptical profile.
This mechanical consistency, combined with a signal-to-noise ratio of approximately 65dB, demonstrates effective control of vibrations and background noise, ensuring stable sound reproduction without the need for any specific corrective measures.
The Luna3 delivers an analogue signal via its RCA output, featuring a design without a built-in preamplifier in order to maintain a direct, unprocessed signal, which means it must be paired with an external phono stage for amplification and integration with the rest of the system. This approach allows you to build a coherent audio system based on your chosen components, whilst maintaining a simple structure focused on analogue reproduction.
The system is completed by an automatic stop function at the end of playback, which halts rotation to minimise wear on the diamond stylus and the record, thereby ensuring safe use and seamless integration into a home hi-fi system.
| 1 | High mass acrylicplatter |
| 2 | Removable headshell |
| 3 | Copper core motor |
| 4 | High quality tonearm |
| 5 | Servo motor control |
| Specifications | |
| Product type | Turntable |
| Type of turntable | Manual |
| Drive system | By belt |
| Playback speeds | 33 and 45 rpm |
| Cartridge | Audio-Technica VM95E |
| Diamond type | Elliptical |
| Tone arm type | Straight |
| Tone arm material | Aluminum |
| Tone arm length | 8,6 inch (218.5mm) |
| Cartridge output voltage | 4mV |
| Fréquency response | 20Hz-22kHz |
| Outputs | 1x RCA 1x 12V Trigger |
| Platter | 300mm |
| SNR | 65dB |
| General | |
| Power supply | 12V 1500mA |
| Power consumption | 5W (Max) |
| Dimensions | 420x112x330mm |
| Weight | 3.5kg |
| Color | Black |
| Package | 1x Acrylic Platter 1x Headshell with Stylus 1x Platter Mat 1x Dust Cover 1x Counterweight 1x Plinth 1x 45 Adapter 1x Rubber Belt 1x 12V Power Adapter |
