NEUTRIK NC4FXX-BAG 4 Pole Female XLR Connector (Unit)
The Neutrik NC4FXX-BAG is a 4-pole female XLR cable connector designed for audio, broadcast, low-voltage power supply, and technical link applications requiring a reliable and durable connection.
Reference : 21778
7,90 €tax incl.
6,58 € tax excl.
Shipping date: 17-11-2026.
Neutrik NC4FXX-BAG 4 Pole Female XLR Connector Silver Plated Ø8mm (Unit)
Photo of the NEUTRIK NC4FXX-BAG
The Neutrik NC4FXX-BAG is a 4-pole female XLR cable connector designed for audio, broadcast, low-voltage power supply, and technical link applications requiring a reliable and durable connection. Part of the XX series, it incorporates the design improvements that built Neutrik’s reputation: simplified assembly, improved mechanical strength, and optimized contact integrity. It features a die-cast zinc housing with black KTL finish, silver-plated brass contacts (2µm Ag over 2µm Ni), and a robust latch locking system. Its solder connection accepts conductors up to 1.5mm² (16AWG) and cables from 3.5 to 8mm in diameter. The chuck-type strain relief system provides excellent pull-out resistance while securely holding the cable in place. Electrically, it supports up to 10A per contact, a rated voltage below 50V, contact resistance ≤ 3mΩ, inter-contact capacitance ≤ 7pF, and insulation resistance > 10GΩ. Compliant with IEC 61076-2-103, rated IP40 and UL94 V-0, it operates in a temperature range from -30°C to +80°C. This model is a reference solution for the manufacture or maintenance of demanding professional cables.
Dimensions of the NEUTRIK NC4FXX-BAG
Technical Specifications
Product typeFemale cable XLR connector
Number of poles4 poles
Connection typeSolder
LockingLatch lock
Compatible cable diameter3.5 - 8.0mm
Max. conductor cross-section1.5mm² / 16AWG
Rated current10A per contact
Rated voltage< 50V
Contact resistance≤ 3mΩ
Insulation resistance> 10GΩ
Dielectric strength1.5kVdc
Capacitance between contacts≤ 7pF
Materials
BodyDie-cast zinc
Body finishBlack KTL
ContactsBrass (CuZn39Pb3)
Contact platingSilver 2µm over Nickel 2µm
InsertPolyamide PA66
Strain reliefPolyacetal (POM)
BootPolyurethane
Lifetime> 1000 cycles
Protection ratingIP40
StandardIEC 61076-2-103
FlammabilityUL94 V-0
Operating temperature-30°C to +80°C
Package1x Neutrik NC4FXX-BAG
Insulation materialPolyurethane (PUR)
Max cable diameter (mm)8.0
Mounting typeTo weld
ConnecticFemale
Contacts number4
ConnectorXLR
NEUTRIK NC4FXX-BAG 4 Pole Female XLR Connector Silver Plated Ø8mm (Unit)
The Neutrik NC4FXX-BAG is a 4-pole female XLR cable connector designed for audio, broadcast, low-voltage power supply, and technical link...
