VIBORG CM203G Male XLR Connector (Unit)
This Viborg CM203G 3-pole male XLR socket features exemplary design thanks to the use of premium materials. The socket contacts are made of pure copper to ensure excellent audio signal conductivity. These contacts also benefit from a triple plating of OFC copper, silver, and 3μ gold. As silver is the best electrical conductor, it maximizes the transmission performance of the socket, while rhodium protects the contacts against corrosion, significantly extending their service life.
Reference : 22029
32,50 €tax incl.
27,08 € tax excl.
Shipping date: 17-11-2026.
Viborg CM203G Male XLR Socket Pure Copper OFC Copper / Silver / 3μ Gold Plated (Unit)
VIBORG CM203G
Dimensions VIBORG CM203G
Technical Specifications
Product typeXLR socket
GenderMale
Number of poles3 poles
Contact materialPure copper
Contact platingOFC Copper
Silver
3μ Gold
Body materialBrass + polished finish + gold plating
InsulationPTFE
Acceptable conductor diameterØ2mm
Dimensions26 x 31 x 20mm
Outer diameter21.5mm
Depth22mm
Packaging1x Viborg CM203G
Max cable diameter (mm)2.0
Mounting typeTo weld
ConnecticMale
Contacts number3
Max panel thickness (mm)N/A
ConnectorXLR
Contacts Plating (Connector)Copper
VIBORG CM203G Male XLR Connector Pure Copper OFC Copper / Silver / Gold 3μ Plated (Unit)
This Viborg CM203G 3-pole male XLR socket features exemplary design thanks to the use of premium materials. The socket contacts are made of pure...
