AUDIOPHONICS DAP / DAC Sabre ES9018 MK2 100Mhz Odroid C-2
Here is the full version assembled and tested in our workshops of our latest Sabre family converter combined with an audio / video file player based on an Odroid C-2.
By buying this product you get 57 loyalty points
Reference : 10390
579,00 €tax incl.
482,50 € tax excl.
This hybrid solution combining high-performance converter and electronic dematerialized reader is equipped with the best in each field.
It allows you to easily have an unconventional conversion quality that supports all sampling rates.
Equipped with two digital audio inputs, an RJ45 Ethernet port, 4 USB 2.0 ports, a selection of sources and a volume control it will quickly become the absolute reference in this price range.
This product is currently compatible with the following software solutions:
Software solutions:
  • Volumio
  • Diet PI
  • Virtually all solutions for Odroid C-2 managing I2S output on GPIO
Features:/ Strong>
  • White Oled Display
  • Integrated power supply (including powern regulated linear dedicated to the Odroid C-2)
  • Transformer Tornelle Encapsule Talema (Ireland) ultra low noise and very low radiation
  • Inputs: 1x Optical, 1x Coaxial and 1x I2S (To which the Odroid C-2 is connected)
  • Outputs: 1x RCA stereo, 1x XLR stereo, 1x HDMI (depending on the software solution selected)
  • Ethernet RJ45 port
  • USB port Type A x4
  • Decoding up to 32bit 384kHz (I2S) per Sabre ESS ES9018
  • THD + N: -120dB
  • DNR: 127 dB
  • FDO output stage (full differential output)
  • AOPs High fidelity low noise: 6x JRC 5534 (Japan Radio Co ltd) including two on DIP8 support (to be changed at leisure)
  • Clock 100MHZ low drift
  • Settings: Phase +/-, Rolloff fast / slow, DSD IIR bandwith 47k / 50k / 60k / 70k
  • Selecting sources by pushbutton
  • Volume control via push-button (+/-)
  • Housing 100% Aluminum
  • Anti-slip rubber feet
  • Dimensions of the case: 350 x 240 x 90 mm
  • Weight: 3.4 kg
  • Supplied mains cable
  • Comes with a Micro SD card containing the operational Diet-Pi release
Dedicated aluminum remote control (not included):itle = "audiophonics es9018 MK2" href = "http://www.audiophonics.com/fr/transmission-sans-fil/audiophonics-telecommande-aluminium-noire-es9018-dac-p-9294.html" target = "_ blank ">Audiophonics ES9018 Remote Control
Note: Since the converter is connected to the ODROID C-2, the USB-B AUDIO port is not active on the converter.
es9018 mk2 odroid DAC
This version ES9018 MK2 includes a clock 100MHZ
InputRJ45
OutputHDMI
DAC / ADC ChipES9018
Max sampling rate384kHz
ColorSilver
Piotr
After very positive impressions with AUDIOPHONICS PGA2310 Preamplifier Volume Control bought some time ago , I have decided to order a/m Network Player AUDIOPHONICS DAP / DAC Sabre ES9018 MK2 100Mhz Odroid C-2 . The Network Player arrived completely assembled with SD card containing Diet Pi software. I have swapped software for my favourite Volumio . Connected to home LAN network . Music Library stored on NAS has been quickly scanned and after some minutes I was ready to listen to the music.
I’m impressed by the quality of sound offered by a/m unit . In my opinion DAC itself represents high end value in terms of reproduction of audio files. I was able to test it with music files up to 24bit/192 Khz. No any problems , no dropouts , no crankling noises from speakers . The HD tracks are played without any side effect very often encountered during playback of HD files. The quality of sound is great . It simply sounds as good as musicians and sound engineers intended during recording. Have tested streaming of audio files from NAS via internal Odroid IS2 bus to DAC (internally) and playing CDs via SPDiF and Toslink inputs into DAC.
My amplifying system consist of AUDIOPHONICS PGA2310 Preamplifier Volume Control and power amplifier. Decided to remove preamplifier from system and drive power amplifier directly using volume control embedded with this Network Player – Sabre DAC. After extensive testing I wasn’t able to distinguish any difference between excellent PGA2310 Preamplifier Volume Control and embedded volume control.
Internal volume control is also supported by very clear, bright, easy readable from distance 4-5m display showing volume value in dB steps.
AUDIOPHONICS DAP / DAC Sabre ES9018 MK2 100Mhz Odroid C-2 gives freedom in choosing of software solutions . Unit offers outstanding sound quality either form Odroid C2 via internal I2S rails and via SPDiF coax inputs and Toslink from external sources. This is topped by excellent volume control supported by clear and bright display.
My only reservation concerns lack of asynchronous USB input . This unit USB uses bus for I2S transmission from Odroid C2 into DAC. But even without this functionality Network Player AUDIOPHONICS DAP / DAC Sabre ES9018 MK2 100Mhz Odroid C-2 offers excellent value given its modest price tag . Highly recommended.
Such products represents right answer against commercial audio industry dominated by over-priced audio components .
This review has been posted for AUDIOPHONICS DAP / DAC Sabre ES9018 MK2 100Mhz Odroid C-2
Here is the full version assembled and tested in our workshops of our latest Sabre family converter combined with an audio / video file player...
