SMSL Sanskrit Pro-B DAC AK4490EQ 32bit/384khz DSD aptX Bluetooth 4.0
By buying this product you get 25 loyalty points
Reference : 10202
259,00 €tax incl.
215,83 € tax excl.
Dramatically evolving from the now famous SMSL Sanskrit, this powerful converter offers you the possibility to play your high resolution PCM files up to 32bit 384kHz and DSD128.
The Sanskrit Pro-B has 2 coaxial and optical Toslink S / PDIF inputs, a USB-B 2.0 input. and an analog RCA stereo output.
Versatile, it also gives you the opportunity to exploit this potential remotely with a built-in Bluetooth 4.0 module.
Used as a digital output, this device acts as a particularly powerful DAC.
It incorporates an Asynchronous C-Media CM6632A USB interface with a special SMSL firmware associated with an AK4490EQ AKM converter: an amazingly efficient pair.
The Sanskrit Pro-B can be connected to your TV, CD / DVD / HDD, etc.
Features:/ Strong>
  • DAC AKM AK4490EQ
  • USB interface C-Media CM6632A (SMSL version) Asynchronous (32bit 384kHz, DSD 2.8MHz, 5.6MHz)
  • Bluetooth Module 4.0
  • Range: 7 meters
  • Apt-X Lossless / Lossless Audio Transmission
  • Jitter extremely low
  • THD + N: 0.0006% to -3dBFS
  • Noise Ratio: 120dB
  • Dynamic range: 118dB
  • Frequency response: 20Hz - 25kHz to -0.3dB
  • USB 2.0 port
  • Inputs: Coaxial S / PDIF, Optical Toslink (24bit 192kHz)
  • Output: RCA Stereo
  • Chassis 100% Anodized aluminum
  • Dimensions: 144x98x36mm
  • Weight: 850g
  • Power supply 9V DC 1.3A included
  • USB-A to USB-B 2.0 cable provided
Qobuz
Test in French (Click here)
[Img-12356-left-thickbox_default]
[Img-12357-left-thickbox_default]
[Img-12358-left-thickbox_default]
[Img-12359-left-thickbox_default]
[Img-12360-left-thickbox_default]
[Img-12363-left-thickbox_default]
[Img-12362-left-thickbox_default]
Illustration system with devices in the range.
[Img-12364-left-thickbox_default]
[Img-12365-left-thickbox_default]
