By buying this product you get 28 loyalty points
The SMSL R100 is a digital-to-analog converter featuring an R2R architecture, designed to process high-resolution PCM and DSD signals. It relies on two professional ADI AD1861-J DAC chips, combined with a "De-glitch" processing and S/PDIF digital filtering intended to reduce conversion errors and jitter during transmission.
Designed for hi-fi installations as well as desktop use, it combines R2R conversion, a parametric equalizer accessible via a browser and gold-plated connectors. Its CNC-machined chassis, completed by two transparent panels, protects the internal components while keeping the circuit visible.
The SMSL R100 adopts an R2R conversion architecture based on two ADI AD1861-J DAC chips. It also integrates a proprietary high-resolution DSD conversion algorithm, capable of processing DSD signals while retaining the characteristic operation of an R2R architecture. The "De-glitch" circuit reduces transient errors and distortion generated during conversion, in order to maintain a stable and accurate reproduction.
For signals transmitted through the S/PDIF interface, the R100 uses a digital filtering algorithm developed specifically by SMSL. It acts on clock jitter and disturbances related to signal transport, which improves transmission stability and reduces information loss during digital processing. Channel separation and soundstage accuracy are thus preserved without adding unnecessary processing to the signal.
The R100 features a configurable PEQ parametric equalizer accessible from a web interface, without installing any specific software. The user can choose between Direct EQ mode and two customizable profiles, EQ1 and EQ2, then save the settings directly in the device. This organization allows quick adaptation of the system's response to different speakers, different headphones or various listening uses.
The gold-plated input and output connectors are more resistant to oxidation and maintain a stable electrical contact over time, reducing losses and transmission variations. The CNC-machined chassis receives several finishing and polishing operations, forming a rigid structure that protects the internal components against vibration and shock. Its two transparent panels make the electronic layout visible, while its format allows it to be installed in a hi-fi system or on a desk.
| 1 | Input selector |
| 2 | EQ selector |
| 3 | Screen |
| 4 | Standby indicator |
| 5 | RCA output |
| 6 | Toslink Optical input |
| 7 | USB-C input |
| 8 | Coaxial input |
| 9 | Power port |
| 10 | XLR output |
| Specifications | |
| Product type | DAC R2R |
| Inputs | 1x USB-C 1x Toslink Optical 1x Coaxial |
| Outputs | 1x RCA stereo 1x XLR stereo |
| DAC chips | 2x ADI AD1861-J |
| Supported sampling rates | USB: PCM 32bit 768kHz, DSD512 Optical / Coaxial: PCM 24bit 192kHz, DSD64 (DoP) |
| Total harmonic distortion plus (THD+N) | 0.003% (-90dB) |
| Dynamic range | RCA: 108dB XLR: 107dB |
| Signal-to-noise ratio (SNR) | RCA: 108dB XLR: 107dB |
| Output level | RCA: 1.75Vmrs XLR: 3.5Vrms |
| Output impedance | 33Ω |
| Compatibility | Windows 7/8/8.1/10/11 (Driver required) Mac OSX10.6 and later, Linux (No driver required) |
| General | |
| Supply voltage | 100-240V AC |
| Dimensions | 170 x 39.8 x 136mm |
| Weight | 712g |
| Color | Silver |
| Package | 1x SMSL R100 1x Power cable 1x USB-C to USB-A cable |
| Input | SPDIF |
| Input | USB |
| Input | Optical |
| Output | RCA |
| Output | XLR |
| DAC / ADC Chip | R2R LADDER DAC |
| Color | Silver |
| Networking | No |
| Remote Control | No |
