AUNE X5s 24bit DSD High Fidelity Digital Audio Player (CPLD) Silver
By buying this product you get 22 loyalty points
Reference : 10503
229,00 €tax incl.
190,83 € tax excl.
AUNE unveils the X5s, a 100% digital audio player supporting virtually all formats including the DSD.
Based on the format of the X1s, it is capable of supplying high-resolution audio to all DAC's thanks to its connectivity (AES / EBU, Optical Toslink, Coaxial RCA). It accesses the files exclusively through its embed SD card reader.
With no operating system, this transport can reproduce the original recording in all its accuracy.
It is designed to be the natural companion of the X1s and then becomes a top-of-the-range set that provides a high-level DSD128 compatible digital source.
Features:
  • Architecture ARM + CPLD + DSD1793
  • High precision clocks Crystek
  • OLED display
  • Control with IR remote control
  • Supported formats: PCM 24bit 192kHz (WAV / FLAC / APE) and DSD
  • THD + N: 138.8dB at 1kHz, 0dB
  • FS Jitter: 2.7NS (PP) at 1kHz, 0dB
  • Input : SD Card Reader (128GB)
  • Transformer-insulated digital outputs: AES / EBU, RCA coaxial, Toslink optics
  • Dimensions: 171x145x45mm
  • Remote control battery not included: CR2032 (available as accessory)
  • Color : silver
[Img-14383-left-thickbox_default]
[Img-14384-left-thickbox_default]
[Img-14388-left-thickbox_default]
(Illustration with the DAC Aune X1s)
[Img-14821-left-thickbox_default]
InputSD Card
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate192kHz
ColorSilver
