Choisir son association avec l'IEC Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du...
This mono single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced audio signal on XH2.54mm connector.
This stereo single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced stereo audio signal on XH2.54mm connectors.
This stereo single-ended to balanced module recovers an unbalanced signal via its RCA inputs on screw terminals, and outputs a balanced stereo audio stream on screw terminals (XLR). Two TI NE5532P balancer OPAs handle audio signal processing. DIP8-mounted, they are easily replaceable according to your preferences.
This 1.5m SMA male to SMA female cable allows you to connect your Bluetooth antenna to your module. This cable has a silver-plated copper conductor, PTFE insulation and a braided silver-plated copper wire shield. The whole thing is encased in a FEP (fluorinated ethylene propylene) sheath to give a result that's both flexible and strong.
This SMD LED light bulb with BA15S base has five cool blue LEDs. It is ideally suited for vu-meters, tuners or other lighting of your HiFi devices and DIY projects.
This Aviation GX16 type connector offers you the possibility to create cables whose connections will be particularly robust and resistant. They are suitable for all types of mounting.
These GX16 aviation connectors offer you the possibility to create cables with particularly robust and resistant connections. They are suitable for all types of mounting.
This socket and circuit breaker tester allows you to test your installation safely. Among other things, this product can detect a lack of earth, phase reversal, or a lack of phase or neutral. This small tester can save lives and prevent fires, and should be included in every electrician's toolbox.
These gold-colored steel BTR socket head screws are particularly useful for connectors with a screw-type cable fixing system, thus replacing flat-head screws. These screws provide a better tightening of the cable.
These banana plug sockets feature gold-plated copper alloy contacts for enhanced conductivity and resistance to corrosion and oxidation. They accept 4mm banana plugs.
This module allows the output to be switched between 1 and 2 seconds after being powered. During this time, the inrush current is damped by the 15W resistance. It is connected after the power switch.
