Choisir son association avec l'IEC Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du...
This lead-free tin solder consists of 99.3% tin and 0.7% copper. This composition ensures excellent conductivity, making it ideal for Hi-Fi applications, whether for soldering on PCBs or cables.
This cable sold by the meter includes a 2.6mm² (13AWG) cross section stranded conductor. This conductor is made of tinned OFC Copper, ensuring good signal conductivity. The latter is covered with a black Silicone sheath for an external diameter of 4mm.
This cable sold by the meter includes a 2.6mm² (13AWG) cross section stranded conductor. This conductor is made of tinned OFC Copper, ensuring good signal conductivity. The latter is covered with a red Silicone sheath for an external diameter of 4mm.
This cable sold by the meter includes a 4.2mm² (11AWG) cross section stranded conductor. This conductor is made of tinned OFC Copper, ensuring good signal conductivity. The latter is covered with a black Silicone sheath for an external diameter of 4,6mm.
This cable sold by the meter includes a 4.2mm² (11AWG) cross section stranded conductor. This conductor is made of tinned OFC Copper, ensuring good signal conductivity. The latter is covered with a red Silicone sheath for an external diameter of 4,6mm.
This toggle switch is of the ON-OFF-ON type. It has one pole and three positions. It is designed for easy installation on PCB. The assembly is done by soldering. The pins are bent at 90° with a comfortable length for installation.
This high quality toroidal transformer delivers a power of 100VA 20V and will be an ideal choice especially for the realization of your DIY projects requiring this voltage.
This high-quality toroidal transformer delivers 100VA of power with a 28-0-28V 1.79A secondary winding. It will fit perfectly into many DIY projects involving the conception / repair / improvement of devices operating with these voltages.
This high quality toroidal transformer delivers a power of 100VA 2x13.5V 3.7A and will be an ideal choice especially for the realization of your DIY projects requiring this voltage.
This high quality toroidal transformer delivers a power of 100VA 2x15V 3.3A and will be an ideal choice especially for the realization of your DIY projects requiring these voltages.
This high quality toroidal transformer delivers a power of 15VA 6V and will be an ideal choice especially for the realization of your DIY projects requiring this voltage.
This high-quality toroidal transformer delivers 250VA of power with a 36V 6.9A secondary winding. It's an ideal choice for DIY projects requiring these voltages.
