Choisir son association avec l'IEC Cette Shucko V 512S silver associée avec une IEC Oyaide C004, constitue une association de haut niveau. Surement la force du...
This high quality toroidal transformer delivers a power of 60VA 6V 10A and will be an ideal choice especially for the realization of your DIY projects requiring these voltages.
This high quality toroidal transformer delivers a power of 160VA 2x24V 3A + 2x15V 0.5A and will be an ideal choice especially for the realization of your DIY projects requiring these voltages.
This black steel bracket allows you to attach a toroidal transformer to it. For this purpose, the support is drilled in its center with a 10.4mm diameter hole. The installation surface is 118mm.
This Toslink all-round fiber optic cable is suitable for connecting a DAC, USB interface to optical or flat panel displays and TVs requiring high quality digital transmission with these metal connectors.Strengths:Corrosion resistant metal connectors High-strength sheath Precision polished fiber termination Plastic protective cap
This little converter is very practical, allowing you to transform a Toslink optical SPDIF audio signal into a coaxial one, and vice versa. It supports Dolby, DTS, AAC and PCM technologies as well as streams up to 192kHz sampling rate. It also incorporates noise reduction technology for clean sound reproduction.
This R-Core transformer is ideal for creating the power supply stage of a DAC or preamplifier for example. It is also equipped with a magnetic screen and an electrostatic screen.
This Bluetooth 5.1 receiver/transmitter and DAC combo turns a classic audio integration into a versatile and practical wireless audio system. It will allow you to wirelessly stream your music from a source such as a smartphone or tablet, or transmit the audio stream from a connected source to headphones or an active speaker.
The transparent silicone insulators are designed to insulate your female blade terminals. They are suitable for terminals that can accept conductors with a diameter of 2.8 mm.
The WinSpeakerz software will allow you to design high quality speakers yourself. This simulator proposes indeed many loudspeakers allowing to evaluate them in a software before launching out in a project by avoiding possible errors.
This Trustfire 18650 Lithium-Ion battery has a capacity of 3400mAh and a nominal voltage of 3.7V. It will provide your devices with a perfectly clean and stable power supply. What's more, it features a complete protection system (PCB 7A) against overvoltage, undervoltage, short-circuit and reverse polarity.
This TS-VU003 VU meter control module lets you integrate magnificent VU meters (sold separately) into your DIY audio creations, whether backlit by LED or bulb. The practical module includes variable resistors for adjusting the input level of each channel and a current regulator for adjusting the luminous intensity of your VU meters' backlighting.
This digital interface module offers a bidirectional system between SPDIF (coaxial and optical) and I2S. The card also provides an analog input. Thanks to its selector, it is possible to change the direction of the transmission.
This small module will allow you to retrieve an I2S signal and then output to HDMI I2S LVDS. The interface supports DSD to enjoy very high resolution files.
This DC-DC converter and regulator module allows to convert with high accuracy an input voltage in the range 6-20V DC to 5VDC 2A. It also incorporates overtemperature and overcurrent protection, reducing the output current when its limits are exceeded.
