IAN CANADA RECLOCKPI Double I2S / DSD Reclocker Low Noise / Low Jitter
Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other digital audio device in synchronous mode to improve I2S/DSD signal quality.
Reference : 15350
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 16-05-2025.
Ian Canada ReClockPi
Double I2S/DSD Reclocker Low Noise / Low Jitter
Ian Canada ReClockerPi Double ReClocker Faible Bruit / Faible Jitter I2S/DSD
Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other digital audio device in synchronous mode to improve I2S/DSD signal quality. It uses high speed discrete logic chips to correct the IR-drop problems of standard multi-bit reclockers, which can result in low and high level logic ripple. Thus, the ReClockPi reduces both noise and jitter.
Key features :
  • The double reclocking discrete logic stage works as a signal conditioner.
  • Low noise. The noise of the output signal on the logic levels is much lower than the output signals of a conventional multi-bit re-clocker.
  • Low jitter. The jitter of the I2S/DSD output = MCLK jitter + additive jitter of the discrete flip-flops.
  • Independent shielding layer over the four-layer PCB to reduce EMI noise.
  • GPIO and dual U.FL I2S/DSD outputs.
  • Supports PCM up to 768kHz and DSD up to DSD1024.
Product typeReclocker
InputsMCLK via U.FL
GPIO
OutputsI2S/DSD via U.FL
MCLK/2 via U.FL
GPIO
Max sampling ratesPCM up to 32bit 768kHz
DSD up to DSD1024
Dimensions75 x 56.5mm
Mounting holes spacing58 x 49mm
Ian Canada ReClockerPi Double ReClocker Faible Bruit / Faible Jitter I2S/DSD Ian Canada ReClockerPi Double ReClocker Faible Bruit / Faible Jitter I2S/DSD Ian Canada ReClockerPi Double ReClocker Faible Bruit / Faible Jitter I2S/DSD Ian Canada ReClockerPi Double ReClocker Faible Bruit / Faible Jitter I2S/DSD Ian Canada ReClockerPi Double ReClocker Faible Bruit / Faible Jitter I2S/DSD Ian Canada ReClockerPi Double ReClocker Faible Bruit / Faible Jitter I2S/DSD
InputU.FL
InputGPIO
OutputI2S
OutputU.FL
OutputGPIO
DAC / ADC ChipNC
Max sampling rateDSD1024
Max sampling rate768kHz
2 reviews
Excellent reclock avec FIFO PI Q3
Très bon upgrade que ce recloker en plus du FIFO PI Q3 de Ian canada. Pour ma part c'est ma dernière modif après avoir installé le FIFO PI Q3 ainsi que des horloges acusillicon et des AOP de chez Sparkos Labs en sortie de mon filtre actif Najda, voir mes avis à ce sujet. Ce que je peux dire c'est que je ne pensais pas avoir un gain réel et bien si, il est certes plus faible que les modifs précédentes mais tout de même il y a un gap. Le plus frappant c'est la sensation de gagner en émotion comme si on retrouvais la chaleur de l'analogique. TOut est plus juste du grave à l'aigu mais surtout mes Altec 414 ont un grave très tendu parfaitement juste comme si j'avais des 416. A achetter lorsque l'on a déjà fait pas mal de modif et que l'on souhaite encore gagné un peu.
This review has been posted for IAN CANADA RECLOCKPI Double I2S / DSD Reclocker Low Noise / Low Jitter
Clearly makes a difference
Very nice improvement to the FifoPi MK3. Highly recommended.
Ian Canada's ReClockPi is a high quality, low noise, low jitter dual reclocker module. It is designed to work with the FifoPi or any other...
