IBASSO AMP18 Amplifier Module for DAP DX340
The iBasso AMP18 is a discrete headphone amplifier module specially designed to accompany the brand's DX300, DX320 and DX340 DAPs. It features an 80-transistor architecture, cascaded current feedback and a complementary push-pull output stage, ensuring stable and controlled amplification. Powered by 12V DC, it achieves 1740 mW + 1740 mW of power under 32Ω in Super Gain mode, extending its compatibility to low-impedance or high-power-demand headphones.
By buying this product you get 27 loyalty points
Reference : 21541
279,00 €tax incl.
232,50 € tax excl.
Shipping date: 11-11-2026.
iBasso AMP18 Transistor Amplifier Module for DAP DX340 Silver
iBasso AMP18 : Front view
iBasso AMP18: A total of 80 transistors
The AMP18 is a discrete architecture headphone amplifier module designed to deliver high output current, using a total of 80 transistors to increase dynamic headroom and load stability. This component density allows for more even current distribution, limiting the individual stress on each transistor while improving the performance of low-impedance headphones.
This hardware foundation is extended by a cascade current feedback architecture, distributing the gain over several stages in order to limit harmonic distortion without reducing bandwidth or introducing intermodulation distortion.
iBasso AMP18: Two-stage amplification
The amplification is based on a two-stage structure, each stage performing a specific function in the gain chain. The first stage combines an operational amplifier and buffer transistors, providing impedance matching and effective isolation from the source, thus preventing any unwanted attenuation or interaction with the next stage. This upstream stabilisation ensures that the transmitted signal retains its amplitude and phase structure.
The second stage uses transistors coupled to a current mirror, used as an active load to increase internal impedance and thus voltage gain. This configuration improves linearity while optimising the operating conditions of the amplifier transistors, reducing dynamic differences between half-waves and contributing to an overall reduction in distortion.
iBasso AMP18: Additional output stage
At the output stage, the AMP18 employs a complementary push-pull configuration, ensuring symmetrical amplification of both positive and negative half-waves. This topology reduces the crossover distortion typical of poorly polarised stages, while balancing the thermal and electrical behaviour of the components.
iBasso AMP18 : in a DX340
iBasso AMP18 : 2x1740mW amplification
iBasso AMP18: External power supply and Super Gain mode
The module accepts an external 12V DC power supply, increasing the available voltage and therefore the power capacity. In Super Gain mode, the power reaches 1740mW + 1740mW under 32Ω, which significantly extends compatibility with low-impedance or moderate-efficiency headphones requiring sustained current.
However, it should be noted that although the AMP18 is compatible with the DX300, DX320 and DX340, only the DX340 allows the use of external power and the activation of Super Gain mode. This distinction determines access to the module's full capacity.
Product typeAmplifier module for DAP
Outputs1x Balanced 4.4mm jack amplified output
1x Balanced 4.4mm jack line output
CompatibilityDX300
DX320
DX340
Amplified output 4.4mm jack
Total harmonic distortion more noise (THD+N)-114dB (No load)
-105dB (300Ω load)
-93dB (32Ω load)
Dynamic range123dB
Signal-to-noise ratio (SNR)122dB
Crosstalk122dB
Frequency response10Hz-40kHz (±0.9dB)
Output impedance1.2Ω
Output powerBattery power supply: 1070mW + 1070mW @32Ω
12V power supply: 1740mW + 1740mW @32Ω
Line output 4.4mm jack
Total harmonic distortion more noise (THD+N)-110dB (No load)
Dynamic range123dB
Signal-to-noise ratio (SNR)123dB
Crosstalk114dB
ColorSilver
Package1x iBasso AMP18
1x Screwdriver
Fixing screw
InputNC
OutputJack 4.4mm
DAC / ADC ChipNC
Max sampling rateNC
IBASSO AMP18 Transistor Amplifier Module for DAP DX340 Silver
The iBasso AMP18 is a discrete headphone amplifier module specially designed to accompany the brand's DX300, DX320 and DX340 DAPs. It features...
