The Moondrop MM3A are compact two-way active speakers designed for near-field listening, monitoring and music production. Their amplification delivers 33W per channel, while the integrated DSP processing handles filtering and signal optimization to combine extended response with controlled reproduction.
Intended for desktop setups and audio workspaces, they combine wired and Bluetooth connectivity, independent volume control and parametric equalization accessible from a dedicated interface. This versatility allows them to be integrated with various sources and their response to be adapted to the listening environment, without the need for an external amplifier.
The Moondrop MM3A are two-way active speakers designed for near-field listening, music production and monitoring. Their digital amplification delivers 33W per channel, i.e. 66W in total, while the DSP processing combines active filtering, adaptive oversampling and a dynamic enhancement algorithm. This architecture handles signal optimization before amplification, in order to adapt the response and dynamics to different uses.
Each speaker combines a Ø1.65cm (0.65") silk dome tweeter with a Ø7.62cm (3") aluminum cone woofer. Two Ø7.62cm (3") passive radiators mounted in horizontal opposition reinforce bass extension without resorting to a conventional port. The specified response reaches 55Hz at −3dB and 50Hz at −6dB, allowing the MM3A to reproduce an extended bandwidth for their compact size.
The driver system and filtering have been designed to limit non-linear distortion, specified at 0.5% at 1kHz, and to maintain accurate timbre reproduction. The cabinet features a curved, low-diffraction geometry intended to reduce disturbances caused by edges and to smooth the off-axis response. This more uniform dispersion makes it easier to position the speakers in a variety of listening configurations.
The MM3A support Bluetooth, USB, 3.5mm auxiliary input as well as optical and coaxial inputs, allowing them to be connected to various digital and analog sources. Independent volume control keeps level adjustment directly on the speaker, without depending on the source setting. In Bluetooth, LDAC compatibility enables high-resolution audio transmission.
In USB and Bluetooth modes, the second-generation DSP can be adjusted from an online interface, with professional parametric equalization. This interface gives access to response settings to adapt the speakers to the room acoustics or listening preferences, while the reference function allows the result to be compared with target response curves. The MM3A can thus be used for everyday listening as well as for audio work requiring an adjustable response.
" Moondrop has gone all out in the design of this very compact and ultra inexpensive set of monitor speakers. The functionality and looks is jaw dropping. The tonality is clearly optimized but obviously there are limits to what you can do with this small of a speaker. Assuming you don't need to play loud, the MMA3 delights with tiny bit of EQ. "
Technical specifications
| Specifications | |
| Product type | Active Speakers |
| Number of ways | 2 |
| Drivers | 1x Tweeter Ø1.65cm (0.65") 1x Driver Ø7.62cm (3") 2x Passive radiator Ø7.62cm (3") |
| Power | 33W |
| Inputs | 1x Jack 3.5mm 1x USB-C 1x Optical Toslink 1x Coaxial Bluetooth 6.0 |
| Output | 1x XLR |
| Input sensitivity | 300mV ±20mV |
| Frequency response | 55Hz-20kHz (-3dB) |
| Supported Bluetooth codecs | AAC, LDAC |
| Supported sampling rates | PCM up to 24bit 96kHz |
| Signal-to-noise ratio (SNR) | ≥ 85dB |
| General | |
| Supply voltage | 100~240V AC, 50/60Hz |
| Dimensions | 107 x 161 x 178.5mm |
| Weight | 2kg |
| Color | White |
| Package | 2x Moondrop MM3A 2x Foam stands 1x Power cable 1x USB-C cable 1x 4-pin XLR cable 1x Jack 3.5mm cable |
| Input | USB |
| Input | SPDIF |
| Input | Bluetooth |
| Input | Jack 3.5mm |
| Input | Optical |
| Color | White |
| Lowest frequency (Hz) | 55 |
| Highest frequency (Hz) | 20000 |
| Power (W) | 33.0 |
| Number of loudspeakers | 2 |
| Speaker type | Active |
| Speaker form factor | Bookshelf speaker |
