TONEWINNER SW-1000 Active Subwoofer
The Tonewinner SW1000 active subwoofer is a bass-reflex subwoofer with a 25.4cm driver delivering up to 200Wrms power at 4 ohms (THD+N<3%). The SW-1000 operates in Class H to adapt its supply voltage to the input signal for high efficiency and a constantly available power reserve.
By buying this product you get 54 loyalty points
Reference : 19257
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 03-11-2026.
Tonewinner SW-1000 Active Subwoofer 200W 4 Ohm 21Hz-240Hz Ø25.4cm
Photo of Tonewinner SW-1000 active subwoofer
The Tonewinner SW1000 active subwoofer is a bass-reflex subwoofer with a 25.4cm driver delivering up to 200Wrms power at 4 ohms (THD+N<3%). The SW-1000 operates in Class H to adapt its supply voltage to the input signal for high efficiency and a constantly available power reserve. It features a wide range of settings, including cutoff frequency, volume and 0°-180° phase inversion. Two events on the front panel enhance bass response. As for inputs, you can choose between an RCA line input or two other inputs: RCA LFE and balanced XLR.
Tonewinner SW-1000: a Ø25.4cm diameter driver
The SW-1000's 25.4cm diameter driver and two bass-reflex events enable it to handle low frequencies while limiting distortion, for an immersive Hi-Fi or home-cinema experience. A 200W amplifier stage ensures powerful, dynamic bass reproduction. The SW1000 can go down to a frequency of 21Hz.
Photo of ToneWinner SW-1000 active subwoofer speaker
Zoom in on the ToneWinner SW-1000 control panel
Tonewinner SW-1000: cut-off control, volume control and phase inversion
The SW1000 features two 9-notch potentiometers for volume and cut-off frequency adjustment. A switch allows you to invert the phase 0° or 180°, depending on the position of the subwoofer in relation to your speakers.
Tonewinner SW-1000 subwoofer overview
Overview of the ToneWinner SW-1000 subwoofer control panel
1Power-on indicator LED
2Cutoff frequency setting
3Volume control
4Phase reversal
5RCA line input
6RCA LFE input
7LFE XLR input
8Power supply voltage switch (110V - 230V)
9Fuse
10IEC power supply
11Power on/off switch
Product typeActive subwoofer
Driver diameterØ25.4cm
Amplification typeClass H (D)
Output power200W
Frequency response21Hz-240Hz
Phase adjustment0° or 180°
Impedance4Ω
Case materialMDF
Inputs1x LFE XLR
1x LFE RCA
1x RCA line input
SPL-max (dB(C), Peak, Music, 1m):107
DRIVER PARAMETER
Frame materialSteel
Voice coil diameterØ50mm
ConeSurface waterproofing semi-pressed paper cone
X-Max±12mm
Magnet size145x20x2mm
Power supply110 AC (50Hz) or 230 AC (60Hz) - Switch available on rear panel
Dimensions360x432x432mm
Gross weight21kg
Net weight19kg
Package1x Tonewinner SW-1000 subwoofer
Excellent surprise!!!
Lassé de mes anciens caissons, tous pourtant de grandes marques d'enceintes, et beaucoup d'écoutes chez les revendeurs, les salons et les amis audiophiles, j'en suis arrivé à la conclusion qu'il y a des fabricants d'enceintes et des fabricants spécialisés en caissons... ces derniers se compte sur les doigts d'une main... Velodyne, REL entre-autres... (pour moi SVS n'en fait même pas partie... trop "home-cinéma" ou trop "boomy", et pour les modèles d'entrée de gamme trop peu de corps sur les instruments acoustiques qui descendent sans le grave, grandes orgues, piano... ).
Chez moi, local de taille "moyenne petite", il ne descend pas aux 21Hz du descriptif de a marque, le 25Hz est à +/- -6db et à partir du 30Hz cela semble "droit"...
Il descend tout de même plus bas dans l'infra, que mon ancien caisson, d'une marque d'enceintes très connue, qui avait pourtant un 30Cms et un ampli plus puissant, ET sans "vrombissement" semi-permanent dans le haut-grave/bas medium (même en mettant la fréquence de coupure au min!) qu'on tant de caisson!!!
Il est très sec pour un bass reflex, il ne traine pas, a beaucoup de matière et d'impact mais contrôlé... il ne bave pas comme la majorité des caissons!
Il se "marie" très bien avec mes B&W 704, qui pourtant descendent déjà plutôt bas, il leur apporte une pression, une extension et une ampleur qui non seulement, ouvre la scène sonore, mais fait penser à une enceinte plus grande!
Je le conseille vivement
This review has been posted for TONEWINNER SW-1000 Active Subwoofer 200W 4 Ohm 21Hz-240Hz Ø25.4cm
The Tonewinner SW1000 active subwoofer is a bass-reflex subwoofer with a 25.4cm driver delivering up to 200Wrms power at 4 ohms (THD+N<3%)....
