FURUTECH NCF BOOSTER-SIGNAL Cables and Power Connectors Flat Holder
The NCF Booster Signal from Furutech, a version of the classic NCF Booster, is a cable and connector support designed to improve cable and connector performance. Having had real success in Japan, it then entered the international market. In this version, the cable is placed on the upper flat part of the connector, unlike the classic version which surrounds the cable.
By buying this product you get 50 loyalty points
Reference : 13086
259,00 €tax incl.
215,83 € tax excl.
Shipping date: 03-11-2026.
NCF BOOSTER SIGNAL
NCF Booster Signal Support plat pour câbles et connecteurs
An indispensable HiFi accessory
What is NCF Booster?
It is therefore a multi-material cable and connector support, improving their performance. Thus, NCF Booster Signal not only raises your cables from the ground to limit contact points to reduce electromagnetic interference, it also provides real cable and connector damping, allowing optimal alignment to reduce static loads. By its action, the NCF Booster Signal allows to obtain a purer and clearer signal.
furutech-ncf-booster-signal-inpage3-jpg.
Examples of use of NCF Booster Signal and NCF Booster.
NCF : Nano Crystal² Formula
Specially developed by Furutech, NCF incorporates a special crystalline material with two active properties. First, it generates negative ions to eliminate static charges. Second, it converts thermal energy into infrared. Furutech therefore combines this material with its outstanding properties with ceramic nano-particles and carbon powder. This ensures piezoelectric damping. The result of using the Nano Crystal Formula² is the ultimate mechanical and electrical damping.
Design of the NCF Booster Signal
Furutech NCF Booster Signal support pour câbles
1ABS resin base with iron counterweight, absorbent iron / silicone / brass plate
2Rod ends made of nickel-plated brass, for fixing
3Nickel-plated brass adjusting screw
4Flat ABS resin and nylon resin holder using Nano Crystal² Formula
ANCF multi-material support. ABS and Nylon resin
BDumping tray
CVibration transmission shaft
DVibration suppression plate (damping). Structure to avoid resonance
ESemi-sealed inner tube. Internal air pressure resists vibration
MaterialMulti-material NCF :
High quality ABS
Nickel-plated brass
Nylon resin
Type of supportFlat
ColorBlack & Silver
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
Bien aussi pour les connexions hdmi
Ne pouvant pour le moment le placer sur un câble de modulation audio, je l'ai testé sur un câble HDMI.
C'est surprenant comme les images ont gagné en fluidités, contraste sur tout sur les noirs et en nettetés. c'est immédiat et bien appréciable pour les yeux.
This review has been posted for FURUTECH NCF BOOSTER-SIGNAL Cables and Power Connectors Flat Holder
The NCF Booster Signal from Furutech, a version of the classic NCF Booster, is a cable and connector support designed to improve cable and...
