This 100% Aluminium case has been designed by AUDIOPHONICS to receive the Raspberry Pi 2 or Pi 3 Model B & the Audiophonics DAC I-Sabre V2 or V3 ES9023. This model has all the markings on the back side. It has all the inputs/outputs necessary for its connection
Aluminium Housing for I-Sabre V4 DAC / Raspberry Pi 3 / OLED Screen
This 100% Aluminium case has been designed by AUDIOPHONICS to receive the Raspberry Pi 2 or Pi 3 Model B & the Audiophonics DAC I-Sabre V4 ES9023. This model has all the markings on the back side. It has all the inputs/outputs necessary for its connection, its power supply (5.5/2.5mm DC jack), drilling for the POWER button, a drilling for HDMI offset, a slot for micro SD card offset, a dedicated drilling for an infrared receiver, as well as a slot for OLED display. It has been designed to give you the efficiency of your Raspberry Pi in a high quality audio environment. Thanks to this particularly robust and elegant housing, you have a high-performance audio solution that offers an excellent price-quality ratio.
| Specifications | |
| Product type | I-Sabre / Raspberry Pi case |
| Material | 100% Anodized Aluminium |
| Serigraphy | Back panel |
| Dimensions | 160 x 140 x 50mm |
| Screen dimensions | 65 x 16mm (Standard HD44782 16x2) |
| Screen fixation holes spacing | 75 x 31mm |
| Weight | 0.8kg |
| Available drilling holes | 1x IR 1x Micro SD Slot 1x RJ45 4x USB-A 1x HDMI (fixation holes spacing : 27mm) 1x Stereo RCA output (ø 12mm) 1x Jack DC 5.5/2.5mm input (ø 9mm) 1x On/Off switch (ø 19mm) |
| Package | Case Screws (only for the case) |
Note: housing delivered bare. Raspberry Pi and DAC I-Sabre sold separately.
