Infineon MA12070 Bluetooth 5.0 2*35W 4Ω
This small, high-performance Class D amplifier module uses an Infineon MERUS™ MA12070 amplifier chip allowing it to develop a power of 2*35W under 4Ω (1% THD+N) while offering high efficiency and precise and detailed sound reproduction. The module provides a USB-A input to connect a storage device such as a USB key or an external hard drive, but above all has a Bluetooth 5.0 receiver as well as a 3.5mm jack input. This allows you to stream and control your music remotely from a smartphone or tablet for example. On the output side, the card is equipped with screw terminals for the speakers. A volume knob is also present for easy and convenient sound level adjustment.
| Specifications | |
| Product type | Amplifier module |
| Inputs | Bluetooth 5.0 1* USB-A (USB-Host) 1* Jack 3.5mm |
| Outputs | Speaker output on screw terminals |
| Amplification chip | Infineon MERUS MA12070 |
| Output power | 2*35W @ 4Ω, 19V, 1% THD+N |
| THD+N | 0.003% |
| SNR | 110dB |
| Frequency response | 18Hz-25kHz |
| General | |
| Supply voltage | 15-19VDC via Jack DC 5.5/2.5mm |
| Dimensions | 80*52mm |
| Input | Bluetooth |
| Input | Jack 3.5mm |
| Input | USB |
| Output | Speaker terminal |
| Channel | 2 (Stereo) |
| Class | Class D / T |
| Amplifier chip | Infineon MA12070 |
| Power (W) | 35.0 |
