TINYSINE TSA7802C Amplifier Module
The TINYSINE TSA7802C is a 2-channel digital audio amplifier module integrating both a Class D amplification stage based on the Texas Instruments TPA3116D2 chip, an Analog Devices ADAU1701 DSP audio processor, and an SPDIFBee digital receiver that converts coaxial S/PDIF streams to I²S.
Reference : 22042
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 18-11-2026.
Tinysine TSA7802C Class D Amplifier Module TPA3116D2 DSP ADAU1701 2x50W 4 Ohm
Photo of the TINYSINE TSA7802C module
The TINYSINE TSA7802C is a 2-channel digital audio amplifier module integrating both a Class D amplification stage based on the Texas Instruments TPA3116D2 chip, an Analog Devices ADAU1701 DSP audio processor, and an SPDIFBee digital receiver that converts coaxial S/PDIF streams to I²S. This all-in-one architecture combines digital audio reception, advanced DSP processing, and power amplification on a single compact board. The TSA7802C delivers up to 2x50W at 4Ω and can efficiently drive 4Ω or 8Ω passive speakers using an external 12V to 24V DC power supply. Its coaxial S/PDIF input supports 16-bit and 24-bit audio streams up to 96kHz, while the ADAU1701 DSP offers extensive sound customization capabilities. The board also features a SigmaStudio-compatible programming port, enabling the creation of advanced audio processing functions such as equalization, active filtering, delay management, bass enhancement, and multiband dynamic processing. Finally, several built-in protections ensure reliable operation, including overvoltage, undervoltage, overcurrent, and thermal protection.
Please note: the remote control button extension port is not available on this module. Only the volume/tone control port is available.
Potentiometer volume control port:
The board features an Ext POT port. You can connect external potentiometers (5K~20K) to control the master volume, treble, midrange, and bass levels. You must first update the DSP firmware with the version compatible with external potentiometers.
  • ADC0: Master volume
  • ADC1: Bass level
  • ADC2: Midrange level
  • ADC3: Treble level
TINYSINE TSA7802C connections
TINYSINE TSA7802C: Programmable ADAU1701 DSP
The core of the audio processing is based on the Analog Devices ADAU1701 DSP, a solution particularly appreciated in embedded audio and DIY audiophile applications.
The board comes with a preloaded DSP program that already allows adjustment of gain, bass, midrange, and treble levels. For more advanced customization, the integrated debugging port allows connection of a compatible USBi programmer and the development of custom processing projects using SigmaStudio.
Users can therefore implement advanced functions such as:
  • parametric equalization
  • active filters and crossovers
  • time alignment and delay correction
  • low-frequency enhancement
  • multiband compression and dynamic processing
  • acoustic optimization of custom loudspeakers
This high level of flexibility makes the TSA7802C an ideal platform for designing active speakers, multi-amplified systems, or custom audio projects.
TINYSINE TSA7802C Module Overview
TINYSINE TSA7802C module overview
112-24V DC Power Input via DC Jack or Screw Terminal
2Coaxial input
3Volume/Tone control potentiometer port
4DSP programming port
5Amplified output via screw terminals
Technical Specifications
Product typeAmplifier module with DSP
Amplifier chipTPA3116D2
DSP chipADAU1701
Input1x Coaxial
OutputScrew terminals
Output power2x 50W @ 4 ohm (21V DC, 10% THD+N)
2x 30W @ 8 ohm (24V DC, 10% THD+N)
2x 18W (12V DC, 10% THD+N)
Supported sampling ratesSPDIF: 24bit 96kHz
I2S: 16bit 48kHz
THD+N0.03% (@4Ω, 1W, 1KHz)
Bandwidth @ ±3dB20Hz-20kHz
Input impedance22KΩ (21V DC)
Minimum load impedance3.2Ω (12V DC)
Gain18dB (12V DC)
24dB (21V DC)
34dB (24V DC)
Efficiency87% (12V DC, 50W @ 4 Ohm)
92% (24V DC, 50W @ 4 Ohm)
Power supply12-24V DC
Dimensions10.5 x 7.5 x 2.2cm
Package contents1x TINYSINE TSA7802C
Channel2 (Stereo)
Power (W)50.0
TINYSINE TSA7802C Amplifier Module Class D TPA3116D2 DSP ADAU1701 2x50W 4 Ohm
The TINYSINE TSA7802C is a 2-channel digital audio amplifier module integrating both a Class D amplification stage based on the Texas Instruments...
