WONDOM AA-AB32992 Class D Amplifier Module MAX9736A 2x12W 8 ohm
The WONDOM AA-AB32992 is a compact Class D stereo amplifier module built around the Maxim Integrated MAX9736A chip. Designed for DIY audio projects, active speakers, multimedia systems, and OEM integrations, it delivers up to 2x 12W into 8Ω with excellent energy efficiency of up to 88%, reducing heat generation and the need for large heatsinks.
Reference : 22259
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 24-11-2026.
WONDOM AA-AB32992 Class D Amplifier Module MAX9736A 2x12W 8 Ohm
WONDOM AA-AB32992
The WONDOM AA-AB32992 is a compact Class D stereo amplifier module built around the Maxim Integrated MAX9736A chip. Designed for DIY audio projects, active speakers, multimedia systems, and OEM integrations, it delivers up to 2x 12W into 8Ω with excellent energy efficiency of up to 88%, reducing heat generation and the need for large heatsinks. The MAX9736A features a filterless Class D architecture, operates from a power supply ranging from 8V to 28V DC, offers high PSRR to minimize sensitivity to power supply noise, and includes overcurrent and thermal protection. The module provides analog stereo audio inputs and differential speaker outputs, ensuring easy integration into a wide range of audio projects. Its spread-spectrum modulation helps reduce EMI emissions, while the integrated Mute and Shutdown functions simplify power management and minimize switching noise. Compact, with dimensions of approximately 91 x 69mm (3.6" x 2.7"), the AA-AB32992 is a cost-effective and high-performance solution for building low- to medium-power stereo audio amplifiers.
WONDOM AA-AB32992
WONDOM AA-AB32992 Overview
1Stereo RCA Analog Input
2Stereo Analog Input via Solder Pads
3MUTE/STBY (Solder Pad)
410-26V Power Input (Solder Pads)
5Stereo Speaker Output
610-26V Power Input (DC Jack or Screw Terminal)
Technical Specifications
Product TypeAmplifier Module
ClassClass D
Amplifier ChipMAX9736A
Inputs1x Stereo Input via RCA
1x Stereo Input via Solder Pads
Outputs1x Stereo Speaker Output via Screw Terminal
Gain31dB
Input Sensitivity307mV
Input Impedance22Kohms
Output Power2x 12W @8Ω THD+N 1%
2x 15W @8Ω THD+N 10%
Bandwidth20Hz-20kHz @8Ω, ±3dB
THD0.0495% @8Ω, 1W, 1kHz
0.2875% @8Ω, 10W, 1kHz
Noise Level239µV
SNR89.4dB @12W 8Ω THD+N 1%
Minimum Load Impedance8Ω
Power Supply10-28V DC (24V typ.)
Idle Power Consumption0.6-1.5W
Standby Power Consumption0.01-0.1W
Max. Current1.5A @ 30W 8Ω
Efficiency87.2% @ 15W 8Ω
Switching Frequency290kHz
Dimensions91 x 69 x 1.7mm
Weight170g / 0.37lbs (±10%)
Package Contents1x WONDOM AA-AB32992
InputSolder pad
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipMAX9736A
Power (W)12.0
The WONDOM AA-AB32992 is a compact Class D stereo amplifier module built around the Maxim Integrated MAX9736A chip. Designed for DIY audio...
