TINYSINE TSA8800C Amplifier Module
New
The amplifier module TinySine TSA8800C combines the functions of a 2.1-channel Class D amplifier, and a DAC / DSP with an SPDIFBee receiver converting the signal to I2S. It is capable of delivering up to 2x100W of power and features a 200W subwoofer output.
Reference : 22539
67,90 €tax incl.
56,58 € tax excl.
TinySine TSA8800C Class D 2.1 TPA3221 DAC DSP ADAU1701 SPDIF 24bit 96kHz 2x100W + 200W 4 Ohm Amplifier Module
Module amplificateur TinySine TSA8800C
The amplifier module TinySine TSA8800C combines the functions of a 2.1-channel Class D amplifier, and a DAC / DSP with an SPDIFBee receiver converting the signal to I2S. It is capable of delivering up to 2x100W of power and features a 200W subwoofer output. To achieve this, it uses TPA3321 amplification chips. DAC / DSP signal processing is handled by an ADAU1701 chip, allowing tone adjustment for each channel. In addition to the SPDIF input, a stereo RCA input is also available.
The ADAU1701 DSP chip features a preloaded program allowing gain, bass, midrange and treble adjustment in the Sigma Studio DSP program/interface. A debugging port is available for Sigma Studio. To access advanced features, the user can program the TSA8800C via the TinySine USBi programmer. The available advanced functions include equalization, crossover, bass enhancement, multiband dynamic processing, delay compensation and more.
The TSA8800C amplifier module is powered by 12V-30V DC and can drive passive speakers with an impedance of 2Ω, 4Ω or 8Ω.
TinySine TSA8800C Amplifier Module Overview
TinySine TSA8800C : Schéma de description
1External LED port
212-30V DC power input
3RCA input
4SPDIF input (SPDIFBee module)
52x100W speaker output
6200W mono subwoofer output
7DSP input/output
8Port for external buttons
9Port for potentiometers
10Mute port
11DSP programming port
12Audio output port
Description of the different ports
DSP input / output port
Three input / output pins are available for the ADAU1701 DSP chip: MP6, MP7, MP0. It is possible to develop a DSP program to meet different requirements. With the default firmware, if you connect these pins to GND, the TSA8800C will output a 1kHz sine wave.
There are three buttons on the module that can control the volume, play / pause, etc... It is also possible to connect external buttons using the dedicated port.
Pinout :
  • P/P : play / pause button
  • VOL + : volume increase and fast forward
  • VOL - : volume decrease and fast rewind
  • 3.3V
TinySine TSA8800B : Pinout du port pour boutons externes
External potentiometers (5K-20K) can be connected to the module to control the master volume, treble, midrange and bass. The DSP software must first be updated. A specially adapted potentiometer kit is sold separately.
Pinout :
  1. ADC0: master volume
  2. ADC1 : bass volume
  3. ADC2 : midrange volume
  4. ADC3 : treble volume
The TSA8800C DSP detects both the Bluetooth signal and the RCA signal, but the default program gives higher priority to Bluetooth. If the Bluetooth signal is detected, the TSA8800C will output a Bluetooth audio source; otherwise, the RCA output will take over. It is also possible to develop a DSP program to meet different requirements, then load the new DSP program using the USBi JTAG Sigma DSP programmer (sold separately).
Connection modes and buttons
TinySine TSA8800C : Schéma d'un branchement classique
Technical Specifications
Product TypeAmplifier module
Amplification TypeClass D
Channels2.1
Power (stereo output)2x 112W @ 3Ω, 10% THD+N
2x 105W @ 4Ω, 10% THD+N
2x 100W @ 3Ω, 1% THD+N
2x 88W @ 4Ω, 1% THD+N
Power (subwoofer output)208W @ 2Ω, 10% THD+N
Inputs1x SPDIF Coaxial
1x Stereo RCA
OutputsSpeaker output on screw terminals
Subwoofer output on screw terminal
Supported SPDIF Sampling Rate16/24bit 96kHz
I2S Sampling Rate16bit 48kHz
Amplification ChipTPA3221
DSP ChipADAU1701
THD+N0.02% @ 1W
SNR108dB @ A-wt, gain=18dB
Dynamic Range109dB @ A-wt, gain=18dB
Minimum Load Impedance3-4Ω
GainMin : 18dB
Typ : 24dB
Max : 34dB
Efficiency90% @ 100W, 4Ω
Input Impedance48kΩ @ 18dB
24kΩ @ 24dB
12kΩ @ 30dB
7.7kΩ @ 34dB
ProtectionsOvervoltage
Undervoltage
Overcurrent
Thermal protection
Power Supply Voltage10-30V DC (power supply sold separately)
Dimensions145 x 100 x 34mm
Package1x TinySine TSA8800C Module
OutputScrew terminals
OutputSubwoofer
Channel2.1
Channel2 (Stereo)
Amplifier chipTPA3321
Power (W)100.0
TINYSINE TSA8800C Class D 2.1 Amplifier Module TPA3221 DAC DSP ADAU1701 SPDIF 24bit 96kHz 2x90W + 200W 4 ohm
The amplifier module TinySine TSA8800C combines the functions of a 2.1-channel Class D amplifier, and a DAC / DSP with an SPDIFBee receiver...
