WONDOM JAB3+ AA-JA32173 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 2x50W 4 Ohm
The Wondom JAB3+ is an amplifier module capable of developing a power of 2x50W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio solution. Thanks to the latter, the JAB3+ can be programmed with SigmaStudio and AppControl via an intuitive graphical interface.
Reference : 15063
48,90 €tax incl.
40,75 € tax excl.
Shipping date: 09-06-2026.
Wondom JAB3+
Wondom JAB3+ Module Amplificateur Class D Bluetooth 5.0 DSP ADAU1701 2x50W 4 Ohm
The Wondom JAB3+ is an amplifier module capable of developing a power of 2x50W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP for an all-in-one audio solution. Thanks to the latter, the JAB3+ can be programmed with SigmaStudio and AppControl via an intuitive graphical interface (requires the use of a Wondom ICP5 module, not supplied).
In addition to its speaker output, the JAB3+ has an additional mixed audio output that can be used with another amplifier module to create a 2.1 or 4.0 system. The PC interface then allows the amplifier to be configured in mono or stereo mode. In addition, the JAB3+ can be battery-powered to create a portable, high-performance audio system.
Bluetooth 5.0
The JAB3+ uses a Bluetooth 5.0 module as input, supporting AAC, SBC, aptX, aptX LL and aptX HD codecs and enjoying a high reception sensitivity of up to 9dB and -90dBm. This makes it possible to pair the JAB3+ with an audio source. An external antenna port is also available in case the JAB3+ is installed in a box.
DSP ADAU1701
The JAB3+ therefore embeds an ADAU1701 DSP chip for audio signal processing. Four ports allow to mount external potentiometers (sold separately). These will allow you to control volume, gain, bass and treble levels. When used with a Wondom ICP5 module (sold separately), you can adjust many audio parameters via the SigmaStudio software or a control application.
Line input
In addition to the Bluetooth input, the JAB3+ offers a line input. The signal from both inputs can be mixed before being transmitted to the amplifier circuit.
Product typeAmplifier module
Number of channels2
Output power2x50W
PBTL Compatibility
InputsBluetooth 5.0
Line input
Outputs1x Speaker output
1x Line output
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD
Measurements
ParameterConditionsMin.Typ.Max.
Min. load impedance-3.2Ω4Ω-
Efficiency2x50W @ 4Ω, 1kHz-83%
Amplifier gain@ 4Ω, 20Hz-20kHz-25.8dB-
Input sensitivity2x50W @ 4Ω, 1kHz, 23.5dB-770mV-
HFP Cutout frequency-0.25kHz-2kHz
LFP Cutout frequency--20kHz-
SNR2x50W @ 4Ω, THD+N=1%, 25.8dB, A-Weighting-91dB-
THD+N10W @ 4Ω, 1kHz, 25.8dB-0.039%-
Input impedance--10kΩ-
Output noise levelA-Weighting, input connected to GND, 25.8dB-163µV-
DC Offeset--10mV-
Crosstalk separation20Hz-20kHz, Gain = 26dB--60dB-
Alimentation12-26V DC (power supply sold separately) or via battery pack (sold separately)
Dimensions91.44 x 68.58mm
InputJack 3.5mm
OutputPH 2.0mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipN/A
Power (W)50.0
3 reviews
Petit mais costaud
Petit ampli, 2x50W, DSP. Très versatile. Rapport qualité/prix des plus intéressant. Je l'ai acheté pour expérimenter avec les DSP et je ne regrette pas mon achat.
This review has been posted for WONDOM JAB3+ AA-JA32173 Amplifier Module Class D Bluetooth 5.0 DSP ADAU1701 2x50W 4 Ohm
Trés agréablement surpris
Le rapport qualité prix est très intéressant. Acheté à l'origine pour un projet d'enceintes portable, je le trouve tellement bon que je l'utilise désormais à la maison. Couplé au module de programmation (ref AudioPhonics 15703) et au logiciel SigmaStudio, il est possible de faire des configuration spécifique pour chaque enceintes ou lieux d'écoute. Le kit de câble très complet qui va bien, référence Audiophonics 15065.
Impressive
Used it to replace a Jab3 plus Bluetooth board combination.
The pcb material is much thinner and appears like a cheaper build when compared to the older jab3.
I was a bit worried if it will sound as good and... It does. I Don t see any difference in quality for the amplifier part when it comes to sound and because it has Bluetooth built in it actually sounds better than my old "separates" combo.
This board can be configured with Sigmastudio to get the most out of your projects.
One minor fault is that, with my phone, when on APTXHD connections, I can not change the LR balance. Unless it is perfectly in the middle, there is a very high noise. All is ok with AptX, only on HD there is this issue. It could be due to my phone though.
Also, the music itself is ok if I leave the balance centered with HD as well, stereo image is good.
For its price, I find this the perfect amp for portable speakers. Enough power and amazing versatility due to the built in DSP.
The Wondom JAB3+ is an amplifier module capable of developing a power of 2x50W, supporting Bluetooth 5.0 (aptX HD) and integrating an ADAU1701 DSP...
