XDA019 TDA7293 Stereo Amplifier Module 2x 100W 4 Ohm
The XDA019 amplifier module is a stereo module capable of delivering up to 2x 100W under a 4-ohm impedance load. It is based on high-quality components such as two TDA7293 high-power transistors for amplification, two Rubycon 63V 10000uF capacitors for power supply, and an Omron protection relay to ensure the integrity of your speakers.
Reference : 21197
55,90 €tax incl.
46,58 € tax excl.
Shipping date: 20-11-2026.
XDA019 Stereo Amplifier ModuleTDA7293 2x 100W 4 Ohm
Photo of the XDA019 Amplifier Module
The XDA019 amplifier module is a stereo module capable of delivering up to 2x100W under a 4-ohm impedance load. It is based on high-quality components such as two TDA7293 high-power transistors for amplification, two Rubycon 63V 10000uF capacitors for power supply, and an Omron protection relay to ensure the integrity of your speakers. Reliable, stable, and powerful, this small amplifier module is ideal for a DIY amplifier project. It is powered by AC (28V+0+28V) and the transformer power must not be less than 200W.
XDA019 amplifier module overview
1AC power input (28V+0+28V)
2Audio signal input
3Amplified audio signal output
Structure of the XDA019 amplifier module
Product typeAmplifier module
ClassAB
TransistorsTDA7293
Output power2x 100W @ 4 ohm
Input impedance22k
Power supplyAC (28V+0+28V)
Dimensions136x80mm
Spacings127x71mm
Weight250g
Package1x XDA019 amplifier module
1x Screw kit (insulating spacers, screws, etc.)
InputPCB Connector
OutputScrew terminals
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTDA7293
Power (W)100.0
XDA019 TDA7293 Stereo Amplifier Module 2x100W 4 Ohm
The XDA019 amplifier module is a stereo module capable of delivering up to 2x 100W under a 4-ohm impedance load. It is based on high-quality...
