FIIO JT1 Headphones
The FiiO JT1 is a dynamic, circumaural headphone designed to deliver a wide-ranging sound whilst remaining affordable. It features a 50mm dynamic driver to cover the entire frequency range with consistency. Its 32Ω impedance makes it easy to have a power supply available from a variety of sources, allowing for direct use without a dedicated amplifier whilst maintaining a stable response.
Reference : 21645
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 11-11-2026.
FiiO JT1 Circumaural Close-back Dynamic Headphones Ø50mm 32Ω 113dB 15Hz-30kHz
FiiO JT1 : Front view
FiiO JT1: 50mm driver
The 50mm dynamic driver utilises a PEK+PU composite diaphragm reinforced with an aluminium film, which helps to minimise distortion whilst extending the frequency response, resulting in low distortion and improved clarity across the frequency range. This design is complemented by a CCAW voice coil, whose reduced mass improves responsiveness, thereby enabling more precise reproduction of transients.
The system is supported by a magnetic circuit featuring N52 magnets, which increases the flux density to provide better control over the diaphragm’s movement, whilst enhancing bass response. This combination ensures a balance between dynamics and precision, making it ideal for use with a wide variety of sources.
FiiO JT1 : Driver
FiiO JT1: Comfort and ergonomics
The lightweight design of the FiiO JT1 reduces pressure on the head, whilst the adaptive headband naturally adjusts the distribution of pressure, ensuring a secure fit without the need for complicated adjustments. The easily removable ear pads complement this design, making maintenance simple whilst ensuring consistent comfort during extended listening sessions.
Product typeHeadphones
Headphone typeCircumaural close-back
Frequency response15Hz-30kHz
Impedance32Ω
Sensitivity113dB/Vrms @ 1kHz
103dB/mW @ 1kHz
Headphone connectorJack 3.5km
Cable terminationJack 3.5mm
Cable connectorOFC Copper
Cable length1.5m
Weight355g
Package1x FiiO JT1
1x Storage bag
1x 3.5mm jack to 3.5mm jack cable
1x 3.5mm jack to 6.35mm jack adapter
Impedance (Ω)32
Efficiency / Sensitivity (dB)113
Lowest frequency (Hz)15
Highest frequency (Hz)30000
WirelessNo
Headphone / Earphone connectorJack 3.5mm
FIIO JT1 Headphones Circumaural Close-back Dynamic Ø50mm 32Ω 113dB 15Hz-30kHz
The FiiO JT1 is a dynamic, circumaural headphone designed to deliver a wide-ranging sound whilst remaining affordable. It features a 50mm dynamic...
