The FIIO Snowsky Anytime is a supra-aural wireless headphone designed for everyday music listening, both at home and on the go. It combines 40mm dynamic drivers, Bluetooth 5.4 connectivity supporting the SBC and AAC codecs, and active noise cancellation (ANC) to reduce external noise. Its Transparency mode allows you to remain aware of your surroundings without removing the headphones, while its Game mode reduces Bluetooth latency to less than 60ms for better synchronization between image and sound. Equipped with a 500mAh battery offering up to 58 hours of battery life with ANC disabled, the Snowsky Anytime recharges in approximately 2 hours via its USB-C port. It also supports simultaneous connection to two Bluetooth devices. Lightweight, weighing approximately 155g, it features a retro design inspired by Y2K aesthetics, an adjustable headband and ear cushions designed to provide comfort during long listening sessions. Overall, the FiiO Snowsky Anytime is a versatile headphone suitable for music, videos, calls and gaming.
The FIIO Snowsky Anytime features 40mm dynamic drivers, specially tuned by FIIO to deliver sound reproduction suited to music listening. The manufacturer highlights a balanced sound signature and prominent bass, making it suitable for various music genres as well as movies and videos. Wireless transmission relies on the JL7006F Bluetooth chip and supports the SBC and AAC codecs. Bluetooth 5.4 connectivity is designed to provide a stable connection while managing power consumption. The headphones can therefore be used with a compatible smartphone, tablet or computer, without requiring an audio cable between the source and the headphones.
To adapt listening to the surrounding environment, the Snowsky Anytime features feedforward active noise cancellation (ANC). This function helps reduce ambient noise, particularly on public transport or in busy spaces, making it easier to enjoy audio content. Conversely, Transparency mode allows external sounds to reach the listener, which is useful for remaining aware of announcements or people nearby. The dedicated button lets you switch between Transparency mode, noise cancellation enabled and noise cancellation disabled. ANC operation affects battery life: FIIO specifies up to 58 hours of listening with ANC disabled and up to 35 hours with ANC enabled.
Thanks to Bluetooth 5.4, the FIIO Snowsky Anytime can be paired simultaneously with two compatible devices. This feature makes it easy to switch between sources, for example between a computer and a smartphone. The headphones also offer a Game mode, activated by double-pressing the ANC button, which reduces Bluetooth latency to less than 60ms according to the manufacturer. This reduced transmission delay helps synchronize sound with images when gaming or watching content. The integrated controls manage the main functions: the power button switches the headphones on and off, while the volume buttons adjust the sound level and, when held for approximately two seconds, allow you to skip to the previous or next track. A short press on the ANC button selects noise cancellation or Transparency mode, while a double press switches between Game and Music modes.
The Snowsky Anytime features a 500mAh lithium battery and offers up to 58 hours of listening at moderate volume with noise cancellation disabled. The specified charging time is approximately 2 hours via the dedicated USB-C charging port. In standby, FIIO specifies battery life of up to approximately 330 hours when the headphones remain connected to a phone without audio playback. Their weight of approximately 155g, adjustable headband, adaptive flexible hinges and soft ear cushions contribute to wearing comfort. The design draws on Y2K retro aesthetics and the manufacturer's "FIIO Arc" design language.
Technical Specifications
| Specifications | |
| Product type | Wireless Bluetooth Headphones |
| Bluetooth chip | JL7006F |
| Input | Bluetooth |
| Bluetooth version | 5.4 |
| Supported Bluetooth codecs | SBC, AAC |
| Noise cancellation | Feedforward ANC |
| Transparency mode | Allows you to listen to music while remaining aware of surrounding sounds |
| Operating mode | UAC 1.1 (Gaming) UAC 2 (Hi-Fi) |
| Simultaneous pairing | Up to 2 devices |
| Battery | 500mAh lithium battery |
| Charging time | Approx. 2h |
| Battery life | Approx. 58h at normal volume without ANC Approx. 35h at normal volume with ANC Approx. 50h without music with ANC |
| Standby time | 330h connected to a phone without audio playback or ANC |
| General | |
| Color | Black |
| Dimensions | 180 x 160 x 62mm |
| Weight | Net: 155g Gross: 290g |
| Package contents | 1x FIIO Snowsky Anytime Headphones 1x USB-A to USB-C Cable |
| Color | Black |
| Impedance (Ω) | NC |
| Efficiency / Sensitivity (dB) | N/A |
| Lowest frequency (Hz) | N/A |
| Highest frequency (Hz) | N/A |
| Wireless | Yes |
| Cable termination | Wireless |
| Headphone / Earphone connector | Wireless (Bluetooth) |
