HIFIMAN HE1000 Wireless Headphones
The HiFiMAN HE1000 WiFi is an open-back circumaural planar magnetic headphone with a built-in network playback solution, DAC, and amplification integrated directly into the earcups. Designed as a self-contained audio system, it operates in WiFi, Bluetooth 5.1, or USB Audio mode via USB-C.
By buying this product you get 295 loyalty points
Reference : 21782
2 959,00 €tax incl.
2 465,83 € tax excl.
HiFiMAN HE1000 WiFi Open-Back Circumaural Planar Magnetic Headphones WiFi Bluetooth LDAC USB 32bit 768kHz DSD512 8Hz-65kHz
Photo of the HiFiMan HE1000 WiFi
The HiFiMAN HE1000 WiFi is an open-back circumaural planar magnetic headphone with a built-in network playback solution, DAC, and amplification integrated directly into the earcups. Designed as a self-contained audio system, it operates in WiFi, Bluetooth 5.1, or USB Audio mode via USB-C. It uses the acoustic architecture of the HE1000 series with nanometer-thickness planar magnetic drivers combined with Stealth Magnet technology, designed to reduce turbulence and diffraction in front of the diaphragm. Digital processing relies on a proprietary Hymalaya R2R / Hymalaya Mini DAC, compatible with PCM streams from 44.1kHz to 768kHz in 16/24/32bit as well as native DSD from DSD64 to DSD512. In Bluetooth mode, it supports SBC, AAC, aptX, aptX HD, and LDAC codecs. In WiFi network playback mode, the headphones can directly access compatible streaming services such as Qobuz, TIDAL, Spotify, and Apple Music depending on the ecosystem used. Its frequency response extends from 8Hz to 65kHz (±0.5dB), channel separation reaches 105dB at 1kHz, and its net weight is 452g. Battery life is rated at 6.5 to 7.5 hours in WiFi mode, up to 23 hours in Bluetooth mode, with a full recharge in 3 to 4 hours and standby time exceeding 30 days.
HiFiMAN HE1000 WiFi: Lossless WiFi Transmission
The standout feature of the HE1000 WiFi is its high-bandwidth wireless network connection (up to 633 MB/s). Unlike a standard Bluetooth connection, WiFi can carry high-resolution audio streams with significantly higher bandwidth, making it better suited for lossless files and demanding digital music libraries. The headphones connect to your home network and play music directly from compatible platforms or a suitable network environment, reducing dependence on a smartphone as the main source.
HiFiMAN HE1000 WiFi: Planar Magnetic Drivers & Stealth Magnet Technology
The HE1000 WiFi uses planar magnetic drivers based on an extremely thin nanometer-grade diaphragm. This low moving mass promotes fast response, excellent transient tracking, and detailed reproduction across the entire frequency range. The open-back design also contributes to a more spacious soundstage and greater sense of air, particularly appreciated for home listening.
The Stealth Magnet structure developed by HiFiMAN uses specially shaped magnets to reduce sound wave reflections and aerodynamic disturbances generated in front of the diaphragm. The goal is to preserve response linearity, improve the readability of micro-details, and reduce masking effects that can occur with more conventional magnetic structures.
HiFiMAN HE1000 WiFi: Integrated R2R DAC & High-Resolution Compatibility
The headphones feature a proprietary Hymalaya digital-to-analog converter based on an R2R architecture. This internal electronics package allows the HE1000 WiFi to operate as a standalone system without requiring an external DAC. In USB Audio mode, it supports PCM streams up to 32bit 768kHz as well as native DSD512. This integration reduces the signal path length between conversion, amplification, and drivers.
HiFiMAN HE1000 WiFi: Triple Connectivity & Versatile Use
The HE1000 WiFi offers three distinct operating modes. WiFi mode is designed for high-definition wireless home listening. Bluetooth 5.1 mode enables convenient mobile or quick-use scenarios with support for modern SBC, AAC, aptX, aptX HD, and LDAC codecs. Finally, USB Audio mode via USB-C allows a direct wired connection to a computer, tablet, or compatible smartphone while also charging the battery.
HiFiMAN HE1000 WiFi: Battery Life & Design
With a stated weight of 452g, the headphones maintain a comfort-oriented construction for long listening sessions. Battery life varies depending on the mode used: up to 23 hours in Bluetooth mode and around 6.5 to 7.5 hours in WiFi mode. Charging time is rated at 3 to 4 hours, while extended standby can exceed 30 days, making regular use easier without constant recharging.
Overview of the HiFiMan HE1000 WiFi
1USB-C Port
2Power Button
3Multifunction Button
4Volume Control
Technical Specifications
Product typeWireless headphones
Headphone typeOpen-back circumaural
TechnologyPlanar magnetic
DACProprietary Himalaya Mini
InputUSB-C
Wireless connectivityWiFi, Bluetooth
Supported sample ratesPCM up to 32bit 768kHz
DSD up to DSD512
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, LDAC
Frequency response8Hz–65kHz (+/- 0.5 dB)
DAC THD+N0.0055% @ -9dB, 1kHz
DAC + amp THD+N0.009% @ 32 ohms, 1kHz
Channel separation105dB @ 1kHz
Power
Charging time3 to 4 hours
WiFi battery life7 hours
Bluetooth battery life23 hours
Standby battery life30+ days
Weight452g
ColorSilver, brown
Packaging1x HiFiMAN HE1000 WiFi
1x USB-A to USB-C Cable
ColorSilver
ColorBrown
Impedance (Ω)NC
Lowest frequency (Hz)8
Highest frequency (Hz)65000
WirelessYes
Cable terminationWireless
Headphone / Earphone connectorUSB
Headphone / Earphone connectorWireless (Bluetooth)
Headphone / Earphone connectorWireless (WiFi)
HIFIMAN HE1000 WIFI Wireless Headphones Over-Ear Open-Back Planar Magnetic WiFi Bluetooth LDAC USB 32bit 768kHz DSD512
The HiFiMAN HE1000 WiFi is an open-back circumaural planar magnetic headphone with a built-in network playback solution, DAC, and amplification...
