The Moondrop Gravity GM-01 PRO is a wireless gaming headphone designed to make sound localization easier and keep communications clear in-game. Its 50 mm composite dynamic driver, paired with an N52 neodymium magnet, reproduces the ambient details useful for positional awareness.
Designed for long sessions, it combines several connection modes, a lightweight design and a microphone system with a detachable boom. Its 1000mAh battery provides up to 150 hours of use, allowing it to be used with various devices and gaming contexts while limiting interruptions for recharging.
The GM-01 PRO combines a 50mm composite dynamic driver with an N52 neodymium magnet to produce a wide soundstage and make sound localization easier in-game. Its carbon fiber hybrid dome diaphragm combines rigidity, lightness and high internal damping; this design promotes a fast treble response and reproduces the ambient details useful for positional awareness.
The headphone offers four connection modes, including wireless options, to suit different devices and uses. Its transmitter operates at 2.4GHz and features USB-C, commonly used with phones, and USB-A, suited to computers. The GM-01 PRO also supports Bluetooth 6.0, USB audio and an AUX input on a 3.5mm jack, allowing the connection to be chosen according to the source and usage context.
Weighing less than 270g with a clamping force of less than 4N, the GM-01 PRO combines a stable fit with moderate pressure for long sessions. Its breathable fabric ear pads, filled with memory foam, contribute to comfort while reducing outside noise.
The headphone is equipped with a dual-microphone system with beamforming and AI voice enhancement, designed to prioritize the voice and reduce background noise during communications. Its detachable microphone boom lets the headphone adapt to uses without voice chat, while the foam pop filter reduces breath noise and plosives.
The built-in 1000mAh battery provides up to 150 hours of use on a full charge. Fast charging delivers two hours of autonomy in ten minutes, so you can resume a session without waiting for a full recharge.
Technical specifications
| Specifications | |
| Product type | Headphone |
| Frequency response | 20Hz-20kHz |
| Headphone type | Closed-back |
| Driver | 50mm dynamic driver with carbon fiber dome diaphragm |
| Headphone connection | 3.5mm jack USB-C Bluetooth 6.0 UHF 2.4GHz |
| Detachable cable | |
| Bluetooth transmission protocol | A2DP / AVRCP / HFP / HSP / SPP / HID |
| Bluetooth codec | SBC / AAC |
| Battery | 1000mAh |
| Autonomy | 2.4GHz: 100h Bluetooth: 150h |
| Charging time | 2.5h |
| General | |
| Weight | 270g |
| Color | Black |
| Package | 1x Moondrop Gravity GM-01 PRO 1x USB dongle 1x Detachable microphone boom 1x Charging cable |
| Color | Black |
| Impedance (Ω) | NC |
| Efficiency / Sensitivity (dB) | N/A |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 20000 |
| Wireless | Yes |
| Cable termination | Wireless |
| Headphone / Earphone connector | USB |
| Headphone / Earphone connector | Wireless (Bluetooth) |
| Headphone / Earphone connector | Wireless (UHF/RF) |
| Headphone / Earphone connector | Jack 3.5mm |
