By buying this product you get 35 loyalty points
The HarmonicDyne Romantic is an open circumaural headphone designed for full-range audio reproduction, leveraging a 60 mm dynamic transducer with bamboo fibre diaphragm to ensure linear and controlled displacement. It delivers 107 dB SPL/mW sensitivity, relying on a high-efficiency magnetic circuit enabling optimized electro-acoustic conversion and efficient exploitation of available power, while maintaining stable dynamic response across sources of varying character.
The HarmonicDyne Romantic leverages a 60 mm transducer with bamboo fibre diaphragm, whose natural damping stabilizes diaphragm movement, limiting distortion and parasitic resonance phenomena while preserving fluid restitution. This approach extends to an open-backed design, allowing soundstage widening and enhanced spatial perception of sources, while the diaphragm's stiffness-to-mass ratio enables rapid transient response, ensuring coherent dynamic reproduction even across complex orchestral passages.
The headphone integrates a high-efficiency magnetic circuit designed to optimize electro-acoustic conversion by reducing energy losses, thereby enabling efficient exploitation of available power regardless of source. With 107 dB SPL/mW sensitivity, this architecture ensures stable output level across a wide range of devices, from mobile sources to desktop amplifiers, while maintaining sufficient dynamic headroom to preserve level differences without perceptible compression.
Conceived for extended use, the Romantic combines lightweight construction with contoured ear cups conforming to ear morphology, thereby limiting fatigue during prolonged listening or monitoring sessions. Faux leather ear pads with breathable mesh-type internal padding ensure progressive heat dissipation while distributing pressure homogeneously, while the adjustable headband balances mass across the skull, promoting sustained stability without pressure points.
The Romantic comes with a braided hybrid cable combining silver-plated oxygen-free copper and monocrystalline copper, thereby maintaining signal integrity across the transmission chain. The 4-strand structure totalling 924 conductors reduces losses and parasitic interactions, while balanced termination in 4.4 mm jack improves channel separation, contributing to clearer spatial imaging and faithful micro-information restitution in a high-resolution listening context.
| Specifications | |
| Product type | Headphones |
| Headphone type | Open circumaural |
| Speaker type | Dynamic |
| Impedance | 64Ω @1KHz |
| Sensitivity | 107dB SPL/mW @1KHz |
| Frequency response | 10Hz-50kHz |
| Headphone connectors | 2x 3.5mm jack |
| Cable termination | 4.4mm |
| Cable materials | Monocrystalline copper Silver-plated OFC copper |
| General | |
| Dimensions | 230 × 200 × 100mm |
| Color | Black |
| Package | 1x HarmonicDyne Romantic 1x Headphone cable 4.4mm jack to 2x 3.5mm jack 1x Headphone carrying pouch |
| Color | Black |
| Impedance (Ω) | 64 |
| Efficiency / Sensitivity (dB) | 107 |
| Lowest frequency (Hz) | 10 |
| Highest frequency (Hz) | 50000 |
| Wireless | No |
| Cable termination | Jack 4.4mm |
| Headphone / Earphone connector | Jack 3.5mm |
