MOONDROP SKYLAND Open-Back Planar Magnetic Headphones 60 Ohms 96dB 20Hz-20kHz
The Moondrop Skyland is a next-generation open-back planar magnetic headphone designed to deliver exceptionally precise sound reproduction and a wide, expansive soundstage. It is built around a large 100 mm planar driver featuring an ultra-thin nanometric diaphragm (~500 nm) and a high-power neodymium magnet array optimized for uniform diaphragm control and extremely low distortion.
By buying this product you get 84 loyalty points
Reference : 21552
849,00 €tax incl.
707,50 € tax excl.
Shipping date: 01-12-2026.
Moondrop Skyland Open-Back Planar Magnetic Headphone 60 Ohm 96dB 20Hz-20kHz
Photo of MOONDROP SKYLAND
The Moondrop Skyland is a next-generation open-back planar magnetic headphone designed to deliver exceptionally precise sound reproduction and a wide, expansive soundstage. It is built around a large 100mm planar driver featuring an ultra-thin nanometric diaphragm (~500 nm) and a high-power neodymium magnet array optimized for uniform diaphragm control and extremely low distortion. Its structure combines CNC-machined aluminum ear chambers, a suspended carbon fiber headband, and premium earpads for lasting comfort. Designed for faithful and analytical sound reproduction, the Skyland covers a wide bandwidth (10Hz-50kHz) and offers excellent micro-dynamics. It comes with a detachable audio cable featuring 3.5mm jack connectors on the headphone side and a high-quality balanced 4.4mm jack termination for optimal integration into any Hi-Fi or studio system. Two adapters complete the package, enabling XLR or 6.35 mm connectivity.
Moondrop Skyland: 100mm planar driver & high-efficiency N55 magnetic array
The Skyland is built around a full-surface 100mm planar driver combined with an ultra-thin nanometric diaphragm (~500nm) and a high-performance N55 neodymium magnet array. This architecture applies a uniform electromagnetic force across the entire diaphragm surface, ensuring perfectly controlled movement and excellent linearity. The optimized magnetic field delivers extremely fast transient response, highly detailed reproduction, and exceptionally low distortion, even at high listening levels.
Its high acoustic transparency open-back design significantly reduces internal reflections that could degrade the audio signal. Structural contours near the diaphragm feature smooth transitions and a low-diffraction matte surface, promoting a natural, airy, and transparent sound signature.
To protect the diaphragm without compromising acoustic performance, the headphone integrates a woven metal protective grille positioned at an optimal distance. Made of round-surfaced metal wires arranged in an open weave, it preserves open-back acoustic qualities while providing reliable mechanical protection.
This advanced electromagnetic design directly contributes to the headphone’s technical performance:
  • Extended frequency response: 8Hz-34kHz
  • Harmonic distortion: ≤ 0.05 %
  • Excellent micro-detail and transient resolution
  • Wide dynamics and natural reproduction
  • Stable and precise diaphragm motion
The result is a homogeneous, precise, and perfectly controlled sound reproduction across the entire spectrum.
MOONDROP SKYLAND : 100 mm planar driver & high-efficiency N55 magnetic array
Moondrop Skyland: Diaphragm stress balancing & pure silver etched circuit
The Skyland integrates a multilayer pure silver etched circuit combined with tension-balancing technology designed to distribute mechanical stress evenly across the entire diaphragm. This design reduces localized stress during dynamic swings, allowing the driver to maintain minimal distortion and remarkable tonal consistency even at high listening levels.
This multilayer circuit also improves the uniformity of the Lorentz force applied to the diaphragm, limiting split vibrations and contributing to a smoother, more natural high-frequency range. Tension Balance Technology (TBT) further optimizes diaphragm surface stress distribution, delivering refined reproduction, improved dynamic stability, and enhanced finesse when paired with high-end audio sources.
MOONDROP SKYLAND : Diaphragm stress balancing & pure silver etched circuit
Moondrop Skyland: Premium construction & long-lasting comfort
The Skyland combines robust construction with carefully engineered ergonomics to ensure optimal comfort during long listening sessions. Its CNC-machined aluminum ear chambers provide excellent structural rigidity and help minimize unwanted resonances, while the suspended carbon fiber headband contributes to even weight distribution across the head. The premium circumaural earpads, made of leather/lambskin-type material, gently envelop the ears and provide secure comfort. This balanced design reduces listening fatigue while improving mechanical vibration isolation for a stable and enjoyable listening experience.
MOONDROP SKYLAND : Premium construction & long-lasting comfort
MOONDROP SKYLAND : detachable audiophile cable & connectivity
Moondrop Skyland: Detachable audiophile cable & connectivity
The Skyland includes a high-quality detachable cable designed to preserve audio signal integrity and ensure optimal transmission. Its low-loss construction guarantees faithful sound reproduction, while the detachable design simplifies maintenance and future system upgrades. The cable features 3.5mm connectors on the headphone side and a balanced 4.4mm termination, ideal for fully exploiting the performance of compatible headphone amplifiers and Hi-Fi sources. Two adapters are also included for extended compatibility: a balanced XLR adapter and a 6.35mm jack adapter, allowing easy integration into any audiophile listening setup.
Technical specifications
Product typeHeadphone
Headphone typeOpen-back
Driver100mm full-drive planar magnetic driver
Diaphragm500nm ultra-thin diaphragm
Impedance60 Ohm
Sensitivity96dB/Vrms
THD≤ 0.05% (@ 1kHz, 94dB)
Frequency response8Hz-34kHz (IEC61094, Free Field)
Effective frequency response20Hz-20kHz (IEC60318-4, -3dB)
Detachable cable
Headphone connector3.5mm jack
TerminationBalanced 4.4mm jack
WeightApproximately 450g
Package contents1x Moondrop Skyland Headphone
1x Detachable cable 3.5mm to 4.4mm
1x 4.4mm to 4-pin XLR adapter
1x 4.4mm to 6.35mm adapter
Impedance (Ω)60
Efficiency / Sensitivity (dB)96.0
Lowest frequency (Hz)20
Highest frequency (Hz)20000
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
MOONDROP SKYLAND Headphones Open-Back Planar Magnetic 60 Ohms 96dB 20Hz-20kHz
The Moondrop Skyland is a next-generation open-back planar magnetic headphone designed to deliver exceptionally precise sound reproduction and a...
