The SIVGA PENG headphones are closed-back dynamic headphones that combine technology and craftsmanship. They feature 50mm diameter transducers with dynamic diaphragms for high-fidelity sound. Their clear and precise sound reproduction is also immersive thanks to their circumaural design. Their high-end audiophile components are complemented by craftsmanship in their design. The ear cups are machined from solid African Zebrano wood, while the headband is made from lambskin leather for maximum user comfort. Added to this are ergonomic ear pads that provide the necessary comfort during long listening sessions. It is also worth noting that the headphones are fully detachable, allowing each component to be replaced individually for a high level of durability and repairability. In terms of sound quality, the SIVGA PENG is ideal for discerning music lovers thanks to its powerful and rich reproduction.
The SIVGA PENG headphones deliver music reproduction with deep, immersive bass and subtle treble thanks to their 50mm diameter transducers, which cover a wide frequency range in a balanced way. The LCP (Liquid Crystal Polymer) diaphragm material also offers numerous benefits. The rigidity and lightness of LCP provide high responsiveness while reducing unwanted vibrations, while a sapphire composite plating ensures refined detail and optimized clarity.
All of the materials and ergonomics of the SIVGA PENG headphones have been designed to offer durability and comfort during long listening sessions. Lightweight and sturdy, the stainless steel headband ensures excellent support, while the lambskin leather headband adapts to a wide range of head shapes. At the junction between the headband and the ear cups, there is a 180° swivel mechanism for optimal adaptation to the user's head shape. The ear pads naturally fit the contours of the ears for a circumaural fit that provides a very good level of passive isolation.
The SIVGA PENG's solid African Zebrano wood shell immediately catches the eye, giving it a highly elegant appearance. Handcrafting this noble material offers a unique finish combined with all the high-end components of the headphones. Each of these components is also easily removable and replaceable to ensure the longevity of this audiophile gem.
The SIVGA PENG comes with a cable featuring 6N OCC copper conductors for flawless signal transmission. This cable has two 3.5mm jack connectors for headphones and a balanced 4.4mm jack termination for compatibility with high-end HiFi devices. Two adapters are also included, a 3.5mm jack adapter and a 6.35mm jack adapter, to ensure universal compatibility. For storage, a stylish hard case allows you to transport your headphones while protecting them.
Product type | Headphones |
Headphone type | Circum-aural |
Headphone structure | Closed-back |
Transducers type | Dynamic |
Speaker diameter | Ø50mm |
Impedance | 340 ohms |
Sensitivity | 102dB ± 3dB |
Frequency response | 20Hz – 40kHz |
Diaphragm material | LCP polymer (Liquid Crystal Polymer) |
Diaphragm plating | Sapphire Composite |
Shell materials | African Zebrano wood |
Detachable cable | |
Headphone connectors | 2x 3.5mm jack |
Cable terminaison | Balanced 4.4mm jack |
Conductors cable material | OCC 6N copper |
Weight | 341g |
Package | 1x SIVGA PENG headphones 1x Detachable cable 2x 3.5mm jack to 4.4mm balanced jack termination 1x 4.4mm jack to 3.5mm jack adapter 1x 4.4mm jack to 6.35mm jack adapter 1x Hard storage case for headphones 1x Pouch for cable and adapter |
Color | Wood |
Impedance (Ω) | 340 |
Efficiency / Sensitivity (dB) | 102.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 4.4mm |
Headphone / Earphone connector | Jack 3.5mm |
