JRAUDIO PRO-3MAX Line Audio Ground Loop Isolator Transformer XLR / Jack 6.35mm / RCA
The JRAUDIO PRO-3MAX is a professional audio ground isolator with XLR connectivity, designed to reduce hum, unwanted noise, and interference caused by ground loops in an audio system.
Reference : 22432
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 12-11-2026.
JRAUDIO PRO-3MAX XLR Line Audio Ground Loop Isolator Transformer XLR / Jack 6.35mm / RCA
JRAUDIO PRO-3MAX
The JRAUDIO PRO-3MAX is a professional audio ground isolator with XLR connectivity, designed to reduce hum, unwanted noise, and interference caused by ground loops in an audio system. It is inserted between the various devices in a system to isolate the ground connection and limit electrical disturbances that may affect the audio signal. It can be used in configurations combining a computer, audio interface, amplifier, mixing console, or other audio equipment when background noise or interference appears after interconnection. JRAUDIO presents the PRO-3MAX as a professional isolation and noise suppression solution, with a design intended for balanced XLR, RCA, or 6.35mm Jack audio connections.
Technical Specifications
Product typeAudio ground isolator
Inputs1x 6.35mm Jack / Balanced XLR Combo
1x RCA
Outputs1x Balanced XLR
1x 6.35mm Jack
1x RCA
Input impedance600 Ohms
Output impedance600 Ohms
Frequency response20Hz-20kHz (+<0.3dB 1khz)
Insulation resistanceDC 1000V 100m2
Insulation voltageAC 50Hz-60Hz OV-1500V
Fixed loss<0.7dB (1khz / 1Vrm)
CompatibilityPlug and play
Attenuator 0 / -15dB
Dimensions123 x 89 x 40mm
Package content1x JRAUDIO PRO-3MAX
The JRAUDIO PRO-3MAX is a professional audio ground isolator with XLR connectivity, designed to reduce hum, unwanted noise, and interference caused...
