RLISO ISO-200S Audio Isolation Transformer Ground Loop
The Rliso Audio ISO-200S is a stereo transformer-based audio isolator designed to eliminate ground noise and interference generated by ground loops between different sources and electronics. Its two-channel architecture uses a double-shielded circuit as well as transformers made from a specific alloy, ensuring effective isolation between input and output signals while maintaining channel separation.
Reference : 22433
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 12-11-2026.
RLISO ISO-200S Audio Isolation Transformer Ground Loop XLR / RCA / Jack 3.5mm / Jack 6.35mm
RLISO ISO-200S: Front view
Each channel offers XLR, jack 6.35mm, RCA and jack 3.5mm connections, allowing the combination of balanced or unbalanced sources and facilitating conversion between different impedance levels. Thanks to this versatile connectivity, the ISO-200S integrates just as well between a source and an amplifier as within a PA system, audiovisual equipment or a Hi-Fi installation affected by parasitic hum.
Product typeAudio Ground Isolator
Inputs2x XLR
2x RCA
2x Jack 6.35mm
1x Jack 3.5mm
Outputs2x XLR
2x RCA
2x Jack 6.35mm
1x Jack 3.5mm
Input impedance600Ω
10KΩ
Output impedance600Ω
10KΩ
Frequency response20Hz-20kHz
Total harmonic distortion (THD)0.002% @1kHz
Fixed loss0.7dB
Insulation resistance1000V DC 100MΩ
Dimensions130 x 100 x 50mm
Package1x RLISO ISO-200S
The Rliso Audio ISO-200S is a stereo transformer-based audio isolator designed to eliminate ground noise and interference generated by ground loops...
