Jean louis B.
Très efficace
Ce petit appareil est très efficace.
Je l’ai laissé travailler une dizaine d’heures avant de voir sa valeur.
J’ai fait des...
christian g.
filtre
Très bon composant mis à la place des anciens filtres Cabasse Clipper 312 M2, plus de détails et d'ouverture.
christian g.
filtre
mis en remplacement de filtre Cabasse Clipper 312 M2, très bon composant, plus d'ouverture et de détails.
AUDIOPHONICS Active Trigger Sequencer 1 IN / 4 OUT 12V - reviews - There are 7 reviews.
Nuno J.
Fantastic device
I needed to trigger two amplifiers at the same time, and the preamp trigger had not enough power, with this device power is more than enough and the problem is solved, been working for some time flawlessly. Thank you
Nuno J.
Small but a life saver
Plug it and works flawlessly, jack 1 trigger imediatly , jack 2 has 2 sec delay, 3 and 4 plus 1 second delay each. Awesome feature. Tested one port 200mA can trigger 2 fosi ZA3 at the same time which means 100mA each. Box is small also nice
Maciej P.
I am very satisfied with the purchase. I had to slightly modify the device by increasing the capacitance of capacitor C1 in order to delay the trigger activation. It would benefit from having a potentiometer to allow for such adjustment (I needed an 8-second delay). However, for the price, the device itself is very neatly and solidly made. It has an aluminum enclosure and LEDs indicating the activation of individual outputs. I definitely recommend it. Also, the shipping to Poland was fast.
Jelte D.
Smart little helper
Very well designed and built simple little tool to start all your equipment at once but in the order desired.
Too bad it does not want to turn on my Aiyama T20 pre-amp with its notoriously picky trigger function. Any solutions to this would be very welcome!
Eemeli T.
Just the thing I have been looking for!
A simple and cheap solution to a problem of not having enough trigger outputs on my preamp. Now I can power on all my devices at once. The slightly delayed "soft start" is nice addition! Perfect little box and works just as promised.
Nicolas D.
AUDIOPHONICS Trigger Séquenceur Actif 1 Entrée / 4 Sorties 12V
Petit boîtier très pratique.
L'allumage différé évite les plocs à l'allumage.
Mon préamplificateur a une seul sortie trigger et je peu commander le caisson de basse et les amplificateurs de puissance avec ce boîtier.
Je recommande sans réserve !
This active trigger sequencer is hand-assembled in our Audiophonics workshop. It avoids plocks and current peaks in order to switch on and off a...
