WONDOM PS-BC12114 BCPB0 Charging and Protection Module 26650 Lithium Battery 5V 2A
The Wondom PS-BC12114 BCPB0 1S is a highly efficient and reliable charging and protection module, specifically designed for 26650 Lithium batteries. Featuring a 5V boost circuit, it allows the battery to be used as a power bank to charge mobile devices, Raspberry Pis, or other USB devices.
Reference : 21695
9,90 €tax incl.
8,25 € tax excl.
Wondom PS-BC12114 BCPB0 1S Charging and Protection Module 26650 Lithium Battery 5V 2A
The Wondom PS-BC12114 BCPB0 1S is a highly efficient and reliable charging and protection module, specifically designed for 26650 Lithium batteries. Featuring a 5V boost circuit, it allows the battery to be used as a power bank to charge mobile devices, Raspberry Pis, or other USB devices. Its compact, palm-sized design makes it ideal for portable DIY applications. Thanks to the 5V boost circuit, when the BCPB0 is used to power mobile phones, the 5V USB output port can deliver a maximum current of 2A. A Raspberry Pi can be easily and conveniently mounted on the BCPB0 using the pre-mounted standoffs and powered by direct contact between the BCPB0’s pogo pin and the POS4 and POS6 pins of the Raspberry Pi’s GPIO, without occupying its 40 pins. Battery level indicators are provided for visual display. The BCPB0 is equipped with a comprehensive protection circuit, including protection against overcurrent, overheating, short circuits, and overvoltage/undervoltage, thereby ensuring its reliability.
Product typeCharging and Protection Module for 26650 Lithium Batteries
Output voltage5V
Max output current2A
LED indicatorsYes (battery level)
Charge/discharge synchronizationYes
Protection circuitOvercurrent
Overheating
Short circuits
Overvoltage
Undervoltages
Charging current1.5A
Overcharge detection voltage4.235V
Over-discharge detection voltage2.8V
Operating temperature20-50°C
Supply voltage5V DC
Dimensions96.52 x 30.48mm
Mounting holes spacing57.91 x 23.11mm
Package1x Wondom PS-BC12114 BCPB0 1S
Screws
OutputPCB Connector
Output voltage (V)5.0
Output current (A)2.0
Input voltage (V)5.0
Power SupplyBattery
The Wondom PS-BC12114 BCPB0 1S is a highly efficient and reliable charging and protection module, specifically designed for 26650 Lithium...
