BERRYBAK BEA4 Bluetooth Receiver
The BerryBak BEA4 is a Bluetooth 5.4 receiver designed to add high-resolution wireless connectivity to an amplifier, active speakers, or any existing HiFi system. It is based on a Qualcomm QCC3095 chip compatible with high-definition codecs such as LDAC, aptX Lossless, aptX HD, and aptX Adaptive, enabling audio streaming up to 24bit / 96kHz.
Reference : 22078
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 12-11-2026.
Berrybak BEA4 Bluetooth 5.4 Receiver ES9018K2M QCC3095 aptX Lossless LDAC 24bit 96kHz
BERRYBAK BEA4
The BerryBak BEA4 is a Bluetooth 5.4 receiver designed to add high-resolution wireless connectivity to an amplifier, active speakers, or any existing HiFi system. It is based on a Qualcomm QCC3095 chip compatible with high-definition codecs such as LDAC, aptX Lossless, aptX HD, and aptX Adaptive, enabling audio streaming up to 24bit 96kHz. The BEA4 also integrates its own DAC to ensure high-quality digital-to-analog conversion while minimizing signal loss. Connectivity includes Toslink optical and coaxial S/PDIF digital outputs, as well as a gold-plated stereo RCA output delivering a 2Vrms output level. Powered via USB-C and consuming only 0.48W, it offers easy Plug & Play operation. Its external antenna provides a wireless range of up to 80 meters in open space, and a dedicated button allows instant disconnection of a paired Bluetooth device to facilitate pairing with a new source. Supplied with a 1m optical cable, two 2.4GHz antennas, and a user manual, the BEA4 is housed in an elegant compact aluminum enclosure that ensures durability and protection against interference.
BERRYBAK BEA4
Berrybak BEA4 Overview
Thanks to its Toslink optical and coaxial S/PDIF digital outputs, the BEA4 can be connected to an external DAC, amplifier, or soundbar to preserve the integrity of the digital signal. Its gold-plated stereo RCA output with a 2Vrms output level also allows easy integration with traditional HiFi amplifiers, active speakers, or vintage audio systems. This versatility enables it to adapt to a wide variety of setups.
BERRYBAK BEA4 Overview
1USB-C power input
2Toslink optical output
3Coaxial output
4Bluetooth Antenna
5RCA output
6BT unpair button
7BT status LED
8Power LED
Technical Specifications
Product TypeBluetooth receiver
Bluetooth ChipQCC3095
DAC ChipES9018K2M
Outputs1x RCA
1x Coaxial
1x Toslink Optical
RCA Output Level2V RMS
Supported Bluetooth CodecsSBC, AAC, aptX, aptX HD, aptX Adaptive, aptX Lossless
LDAC
Power Supply5V DC 0.5A
Dimensions64 x 95.4 x 26mm
Weight210g
Package Contents1x Berrybak BEA4
1x Toslink Optical Cable
1x Angled 2.4GHz Bluetooth antenna 50mm
1x Short 2.4GHz Bluetooth antenna 21mm
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
Supported Bluetooth codecsaptX Lossless
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX Adaptive
BERRYBAK BEA4 Bluetooth 5.4 Receiver ES9018K2M QCC3095 aptX Lossless LDAC 24bit 96kHz
The BerryBak BEA4 is a Bluetooth 5.4 receiver designed to add high-resolution wireless connectivity to an amplifier, active speakers, or any...
