JANTZEN AUDIO C-COIL 000-6190 Toroidal Coil Copper
Jantzen Audio's C-Coil toroidal coils feature very low resistance and excellent heat resistance. This means they can withstand high power levels without overheating or causing distortion. The model in question tolerates up to 2000W (RMS) / 8Ω. In fact, they are particularly effective for bass induction when filtering your passive hi-fi speakers.
Reference : 21577
74,91 €tax incl.
62,42 € tax excl.
Shipping date: 17-11-2026.
Jantzen Audio C-Coil 000-6190 Toroidal Coil Copper 12AWG Ø93mm 3.9mH 0.05 Ohm
Jantzen Audio C-Coil : Front view
Jantzen Audio
Please note that due to the electromagnetic field inherent in their construction, C-Coils are not suitable for crossovers above 1.20kHz. Likewise, they are not intended for amplification or any other active system.
Each coil is individually tested with the CLIO @ AC 1V 1kHz measurement system.
Product typeToroidal coil
MaterialETP Copper C11000, IACS certified
CoreEpoxy-laminated steel plates
Inductance3.9mH ±5%
Power handling (RMS)2000W / 8Ω
RDC0.05Ω ±10%
Wire diameterØ2.1mm
Section3.31mm² (12AWG)
Outer diameterØ93mm
HeightØ32mm ±3
Weight1.52kg
Inductance (mh)3.9
JANTZEN AUDIO C-COIL 000-6190 Toroidal Coil Copper 12AWG Ø93mm 3.9mH 0.05 Ohm
Jantzen Audio's C-Coil toroidal coils feature very low resistance and excellent heat resistance. This means they can withstand high power...
