JANTZEN AUDIO C-COIL 000-6461 Toroidal Coil Copper
Jantzen Audio's C-Coil toroidal coils feature very low resistance and excellent heat resistance. This means they can withstand high power levels without overheating or causing distortion. The model in question tolerates up to 4000W (RMS) / 8Ω. In fact, they are particularly effective for bass induction when filtering your passive hi-fi speakers.
Reference : 21574
159,00 €tax incl.
132,50 € tax excl.
Shipping date: 17-11-2026.
Jantzen Audio C-Coil 000-6461 Toroidal Coil Copper 12AWG Ø133mm 8.2mH 0.08 Ohm
Jantzen Audio C-Coil : Front view
Jantzen Audio
Please note that due to the electromagnetic field inherent in their construction, C-Coils are not suitable for crossovers above 1.20kHz. Likewise, they are not intended for amplification or any other active system.
Each coil is individually tested with the CLIO @ AC 1V 1kHz measurement system.
Product typeToroidal coil
MaterialETP Copper C11000, IACS certified
CoreEpoxy-laminated steel plates
Inductance8.2mH ±5%
Power handling (RMS)4000W / 8Ω
RDC0.08Ω ±10%
Wire diameterØ2.1mm
Section3.31mm² (12AWG)
Outer diameterØ133mm
HeightØ43mm ±3
Weight2.52kg
Inductance (mh)8.2
JANTZEN AUDIO C-COIL 000-6461 Toroidal Coil Copper 12AWG Ø133mm 8.2mH 0.08 Ohm
Jantzen Audio's C-Coil toroidal coils feature very low resistance and excellent heat resistance. This means they can withstand high power...
