LAIV CLX Cable Lifter
The LAiV CLX is a cable lifter designed to provide both mechanical support and connection stability within an audio system. It raises cables off the floor to isolate them from parasitic contact while structuring their routing, limiting interference-related constraints and facilitating a more legible organisation of the installation.
Reference : 22062
169,00 €tax incl.
140,83 € tax excl.
LAiV CLX : Front view
Beyond this routing function, it acts as an anchoring point by absorbing the tension exerted by stiffer or heavier cables, preventing any displacement or imbalance of the connected electronics. This approach proves particularly relevant with large-gauge power or high-end cables, while remaining compatible with any type of connection, ensuring a stable and orderly installation.
Technical specifications
Product typeCable lifter
ColourBlack and gold
Package contentsSold individually
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
The LAiV CLX is a cable lifter designed to provide both mechanical support and connection stability within an audio system. It raises cables off...
