LAIV HARMONY DAC 2 Balanced R2R DAC Silver
The LAIV Harmony DAC 2 combines a minimalist design with a discrete balanced R2R digital-to-analog conversion, carrying over the architecture that characterized the first generation while adapting it to new operating modes. It supports PCM up to 768 kHz and DSD512, while its discrete class A output stage simultaneously feeds the XLR and RCA outputs with a low impedance, making it easy to pair with any preamplifier or power amplifier. Its modular design also retains simplified maintenance and easy upgradeability.
By buying this product you get 437 loyalty points
Reference : 22398
4 379,00 €tax incl.
3 649,17 € tax excl.
LAIV HARMONY DAC 2 Discrete Balanced R2R DAC OS/NOS 32bit 768kHz DSD256 Silver
LAIV HARMONY DAC 2: Front view
LAIV Harmony DAC 2: Discrete balanced R2R architecture
The Harmony DAC 2 relies on an R2R digital-to-analog conversion stage, based on networks of individual resistors matched to a tolerance of 0.05%. This fully balanced architecture processes the signal polarities separately in order to limit conversion errors and preserve the accuracy of the musical information. PCM conversion can now operate in three selectable modes: NOS, proprietary OS oversampling, or hardware sample rate conversion, while DSD remains processed natively in NOS, without any intermediate conversion.
LAIV HARMONY DAC 2: R2R DAC
LAIV Harmony DAC 2: Class A output stage
Beyond its R2R network, the DAC 2 features a new discrete class A output stage, designed to provide a stable signal to the analog outputs. This allows the XLR and RCA outputs to be used simultaneously, with a low output impedance suited to different types of preamplifiers and power amplifiers. This improvement notably makes it easier to integrate the DAC into several audio chains or listening systems without having to select a single analog output.
LAIV HARMONY DAC 2: Class A output stage
LAIV HARMONY DAC 2: BNC clock input
LAIV Harmony DAC 2: 10 MHz master clock
The DAC 2 has a direct input for a 10 MHz master clock, allowing the entire conversion process to be synchronized with an external reference. This link operates without a DDC or detour through an I2S interface, while the different PCM processing modes allow the DAC's operation to be adapted to listening preferences and the nature of the sources used.
LAIV Harmony DAC 2: Complete digital isolation
The DAC 2 architecture fully separates the input and output stages with dedicated digital isolation. This design limits the propagation of ground loops, noise carried by the USB bus, and interference from upstream connected devices, thereby lowering the residual noise level and preserving low-level information.
LAIV HARMONY DAC 2: Digital isolation
LAIV Harmony DAC 2: Interface and system integration
The DAC 2 replaces the monochrome OLED display of the first generation with a color display, which groups together information on the source, the signal format, and the selected conversion mode. It also adds 12V trigger connectivity, both input and output, to integrate it into the power-up sequence of a complete system. Finally, firmware updates are now performed via USB-C, which simplifies maintenance and software upgrade operations.
LAIV HARMONY DAC 2: color display
Technical specifications
Product typeR2R DAC
Inputs1x Optical Toslink
1x Coaxial
1x USB-B
1x HDMI I2S
1x BNC (Clock)
Outputs1x RCA stereo
1x XLR stereo
Supported sample ratesUSB / I2S: PCM 768kHz, DSD256
Optical / Coaxial: PCM 192kHz, DSD64 (DoP)
Output impedanceXLR: <50Ω
RCA: <25Ω
Output levelXLR: 4.15Vrms
RCA: 2.08Vrms
Frequency response20Hz–20kHz (±0.25dB)
Total harmonic distortion more noise (THD+N)0.0035%
Signal-to-noise ratio (SNR)>125dB
Dynamic range>110dB
Crosstalk<−120dB
Trigger
Supply voltage100-127V AC / 60Hz
220-240V AC / 50Hz
Dimensions255 x 250 x 50mm
Weight4.3kg
ColorSilver
Package1x LAIV Harmony DAC 2
3x Decoupling spikes
1x Remote control (Batteries not included)
1x Power cable
1x Cleaning cloth
InputClock (BNC)
InputI2S via HDMI
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD256
Max sampling rate768kHz
ColorSilver
Remote ControlYes
The LAIV Harmony DAC 2 combines a minimalist design with a discrete balanced R2R digital-to-analog conversion, carrying over the architecture that...
