This balanced Meze cable was specifically designed for use with headphones. It features an exceptional design, using silver-plated Furukawa PCUHD copper conductors, ensuring incredible electrical conductivity for perfect audio signal transmission. Furukawa cables are known for their ability to provide open, yet highly detailed sound with perfectly...
Mogami offers us here a flexible multi-conductor digital audio cable with a compact design. This 110 Ω AES/EBU cable is easy to wire, install and handle. Thanks to its CPP (cellular polypropylene) insulation, the size of the conductors used can be increased furthermore while maintaining a compact overall diameter, resulting in lower attenuation.
This top-of-the-range Mundorf ACW120 wiring cable offers excellent manufacturing quality for maximum conductivity. Its conductors are made of a high-purity copper/silver/gold mix. This model is ideal for wiring super tweeters or tweeters.
This flat wire Mundorf will appeal to amateurs chevronés wishing to design cables loudspeakers or for the shielding by sheets of transformers, condensers or simply of boxes.
The high-end Mundorf SGW215WH/YE wiring cable consists of two 1.77mm² high-purity silver conductors, enriched with one percent gold and insulated with a PTFE sheath. This ensures exceptional conductivity for optimum signal transmission. Ideal for internal wiring of high-end audio equipment.
NCF Furutech Booster Shaft Bar Adjuster are optional parts that can be combined with NCF Booster and NCF Booster Signal. This accessory allows precise height adjustment of NCF Booster cable supports up to +7mm for optimum connector retention.
Neotech BRDCC wires are an excellent UP-OCC copper solution. Professor Ohno's UP-OCC process is recognized in the manufacture of high quality HiFi cables. Cotton (70%) and Polyester (30%) insulation provides an excellent finish to your high-end cable, while protecting it efficiently from mechanical stress.
Neotech CU-AG cabling wire ensures perfect signal transmission, using conductors made of OCC copper alloy and 20% OCC silver for optimal conductivity. Each conductor is insulated with a transparent PE jacket.
This high-end Neotech GP-OAG wire benefits from a design based on the use of the best components available in terms of electrical conductivity. It integrates a very high purity UP-OCC Silver conductor with gold plating.
This Neotech GP-OCG high-end wire benefits from a design based on the use of exceptional components in terms of electrical conductivity. It integrates a very high purity UP-OCC copper conductor with gold plating.
The Neotech LEST-22 wiring wire offers a high quality design, using a single core conductor with a rectangular cross-section of pure UP-OCC silver. This ensures optimal conductivity for perfect signal transmission. It is ideal for high fidelity audio applications to maintain signal integrity.
The Neotech LEST-24 wiring wire offers a high quality design, using a single core conductor with a rectangular cross-section of pure UP-OCC silver. This ensures optimal conductivity for perfect signal transmission. It is ideal for high fidelity audio applications to maintain signal integrity.
Neotech's NEI series is a range of high-end cables. The NEI-2002 cable features two pure silver single-core conductors, both with a diameter of 0.58mm (AWG 23). NEI-2002 features a triple shielding layer with microporous PTFE, AL-Mylar and silver-plated OFC braiding.
Neotech's NEI-3002G is a balanced RCA to XLR cable incorporating two G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while...
The Neotech NEMOI-3220 modulation cables combine PTFE insulation and pure OCC copper conductors with a rectangular cross-section, and are equipped with a particular architecture, allowing a strong reduction of the effect of inductance and capacitance. The result is surprising, revealing qualities often considered contradictory such as a good bass, a...
This Neotech Nemos-1080 high-end speaker cable benefits from an all-inclusive design, incorporating the best possible components for maximum conductivity and optimal signal transmission, resulting in high quality sound reproduction.
The Neotech NES 3003 MKII loudspeaker cable has a special hybrid topology to reduce the effects of capacitance and inductance. Composed of OCC and silver-plated OCC copper, it offers qualities of timbre, dynamics and readability, usually contradictory.Strengths:Double structure OCC and OCC silver plated Shielded speaker cable Anti-static outer casing
This Neotech silver multi-strand cable with PTFE insulation is ideal for rewiring and enhancing tube amplifiers, or any high-end Hifi device with wiring in the air. A wise choice for any enthusiast wishing to dramatically increase the performance of its DAC, amplifier or dedicated to the DIY manufacture of Cinch RCA cable.
This HDMI 2.0 cable integrates as conductors beams of Optical Fiber. These provide an excellent transmission rate up to 18Gbps, very good signal stability, extremely low attenuation while allowing the signal not to be subjected to high levels of electromagnetic interference.
This superb high-end cable is equipped with a 3.5mm male jack connector on the one hand and a 3.5mm female jack connector on the other. It will be particularly useful to take advantage of an extension of a headphone cable that is too short by acting as an extension cable. The materials used for this HPSC-35J contribute to a significant improvement in...
This high-end Oyaide HPSC-X63 cable has a 6.35 jack connector and a 3-pin Mini XLR connector. It has mainly been designed to replace defective or inferior cables on headsets with this type of connector, such as the AKG K712PRO, Pioneer HDJ-2000, etc.
This high quality Oyaide Tunami GPXe power cable is equipped with a Schuko and an IEC C15 connectors, with 24k gold and palladium plated contacts. The conductors of the cable are made of high purity 102 SSC and OFC copper with a cross section of 5.5mm², ensuring perfect electrical conductivity. The cable can withstand voltages up to 600V and currents...
