Connector
Length
0 m - 15 m
Section (mm²)
0 mm - 5 mm
Conductors material (Cable)
Conductors Plating (Cable)
Shielding
Pierre-Marin L.
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba...
Raphael A.
Son trop cristallin et trop orienté sur les médiums
Je l'ai testé vs. mon AUDIOPHONICS LHDC Récepteur Bluetooth 5.0 LHDC SA9910 / DAC PCM5102A 24Bit / 96kHz (moins cher,...
Interconnect Cables
Discover all our interconnect cables, allowing the connection of all types of audio devices.
  • Cables JACK JACK
    Cables JACK JACK
    Discover our range of Jack to Jack audio interconnection cables.
  • Cables JACK RCA
    Cables JACK RCA
    Discover our range of Jack to RCA audio interconnection cables.
  • Cables RCA RCA
    Cables RCA RCA
    Discover our range of RCA to RCA audio interconnect cables.
  • Cables RCA XLR
    Cables RCA XLR
    Discover our range of RCA to XLR audio interconnect cables.
  • Cables XLR JACK
    Cables XLR JACK
    Discover our range of XLR to Jack audio interconnection cables.
  • Cables XLR XLR
    Cables XLR XLR
    Discover our range of XLR to XLR audio interconnect cables.
  • Cables DIN RCA
    Cables DIN RCA
    Discover our range of DIN to RCA audio interconnection cables.
  • ACSS Cables
    ACSS Cables
    Discover our range of ACSS interconnect cables, developed by Audio-GD and used by some of the brand's high-end devices.
