VIABLUE SC-4 Bi-Wiring Speakers Cables 3m (Pair)
ViaBlue ™ SC-4 Silver-Series Speaker Cables have silver-plated strands for the treble range and tin-plated strands for powerful playback of the bass range. The cables are factory-installed ready-made with ViaBlue ™ T6s banana plugs, which have 24 carat genuine-gilded bronze contacts. Technically, all the frequency ranges are cleanly and realistically represented and reproduced in a linear fashion.
By buying this product you get 57 loyalty points
Reference : 2042
570,00 €tax incl.
475,00 € tax excl.
Last items in stock !
Shipping date: 16-06-2026.
Definition. Details. Living music.
High-End quality. Salient Design. ViaBlue ™ Cobra.
SC-4 speaker cables have a transparent and three-dimensional sound and a brilliant, airy quality in the high range. Clean lows and basses homogeneously round the acoustic pattern. Technically, all the frequency ranges are cleanly and realistically represented and reproduced in a linear fashion.
Seperate signal lines for high and low pass.
A control loop serves to hold a certain magnitude constant (negative feedback control, scanning by sensing devices, comparison of the values ​​with the reference value, sending a correction signal when there are deviations, whereupon the deviating state is reset to the initial value).
Silver plating for more brilliance.
The four 4 mm2 leads of the SC-4 more speaker cable consist of ever 7 stranded bundles with altogether 896 individual braids. In order to specialize the sound range for the individual frequency ranges, two of the four veins are silvered and two veins tinned. Through the combination of silver-plated and tin-plated leads, the finest details and brilliance of the treble range as well as the lower frequency signals of the bass range are fully carried and reproduced through the attached speakers.
The two silvered leads are connected with the high tone range of the loudspeakers. By the silver plating finest details will be transferred in the high tone range. The two tinned copper leads are connected with the low range of the loudspeakers. The low-frequency signals are completely transported in the range and shown by the tinning of the copper braids over the attached loudspeakers pressureful.
The SC-4 speaker cables are braided with the ViaBlue ™ Cobra protective sleeve, which also affords at first glance a visual impression of the dynamic quality of the high-end speaker cables. Thes splitters typically used with ViaBlue ™ cables to protect the cable ends from snapping off and, at the same time, provide a professional, well thought out cable routing of the single leads.
Viablue SC-4 review by HiFi-Choice
" The beautifully made SC-4 excels in delivering a refined sound across a wide range of music "
Features:/ Strong>
  • Section conductor 4 x 4mm² (224 x 0.15mm)
  • PVC Insulation
  • Tinned conductor resistance: 4.6mOhm / m
  • Resistance of the conductor plated Silver: 4.4mOhm / m
  • Capacity: 136pF / m
  • Inductance: 0.63μH / m
All ViaBlue ™ cables are manufactured in Germany and are made by hand.
Length (m)3.0
ShieldingNC
Section (mm²)4.00
ConnectorBanana
2 reviews
Linn index qui respirent
Depuis le départ monocâblées en QED, mes Linn index semblent mieux respirer, les câbles sont lourds et donnent confiance. La configuration DAC AlloBoss avec ampli Proton me donne du bon son.
This review has been posted for VIABLUE SC-4 Bi-Wiring Speakers Cables 3m (Pair)
Excellent Cable
Great quality . Superb packaging. Excellent service from Audiophonics.
ViaBlue ™ SC-4 Silver-Series Speaker Cables have silver-plated strands for the treble range and tin-plated strands for powerful playback...
