OYAIDE HPSC-63 Jack 6.35mm to Jack 3.5mm Headphone Cable 1.3m
New
This high-end Oyaide HPSC-63 cable has a 6.35mm jack connector and a 3.5mm jack connector. It has mainly been designed to replace defective or inferior cables on headsets with this type of connector.
Reference : 22734
124,90 €tax incl.
104,08 € tax excl.
Shipping date: 24-11-2026.
Oyaide HPSC-63
Oyaide HPSC-63
102 SSC Conductors
The cable integrates two 102 SSC high purity braided copper conductors, with a 7/7/0.089 configuration. The 102 SSC is the result of extremely controlled machining, resulting in a very high IACS rate of 102.3%. To avoid contamination of the Copper by impurities, Oyaide uses only non-recycled Copper. To go further, the conductor undergoes a mechanical treatment specific to the design proposed by Oyaide, making it possible to remove any impurity or defect. The conductor is finally annealed twice.
xxx
xxx
Insulation, shielding and sheath
These two 102 SSC conductors are covered with TPE insulation and then with 102 SSC copper shielding, with an intermediate silk filling. The shielding is then covered with a second layer of TPE insulation, then with a braided black and white silk sheath of the most beautiful effect and covering 100% of the cable. The latter has the advantage of avoiding static electricity charging and thus limiting noise on the signal.
Product typeJack 6.35mm to Jack 3.5mm headphone cable
Length1.3m
External diameter4mm
Connectors platingJack 3.5mm TRS: Silver + Rhodium plated
Jack 6.35mm TRS: Silver + Rhodium plated
Conductors2x 102 SSC Copper conductors (7/7/0.089)
InsulationTPE
Shielding102 SSC Copper (58/0.089)
SheathBraided Silk
ColorBlack and white
Length (m)1.3
ShieldingYes
Section (mm²)N/A
ConnectorJack 6.35mm
ConnectorJack 3.5mm
This high-end Oyaide HPSC-63 cable has a 6.35mm jack connector and a 3.5mm jack connector. It has mainly been designed to replace defective or...
