FOSI AUDIO Interconnect Cable Male 3.5mm Jack to 2x Males RCA 1.2m
The Fosi Audio 3.5mm male jack to 2x male RCA audio cable is designed to connect a source or device equipped with a 3.5mm jack output to equipment featuring two RCA inputs.
Reference : 22392
29,65 €tax incl.
24,71 € tax excl.
Shipping date: 24-11-2026.
FOSI AUDIO 3.5mm Male Jack to 2x Male RCA Shielded Audio Cable 1.2m
3.5mm Male Jack to 2x Male RCA Audio Cable
The Fosi Audio 3.5mm male jack to 2x male RCA audio cable is designed to connect a source or device equipped with a 3.5mm jack output to equipment featuring two RCA inputs. Measuring 1.2m in length and 6.5mm in outer diameter, it uses conductors made of 28 strands of fine copper combined with copper foil. Its shielding system combines aluminum foil and a copper braid, while the outer PVC jacket covered with a nylon braid provides additional protection. The connector contacts are made of gold-plated pure copper and feature an anodized aluminum alloy body, providing a robust and durable design.
Technical Specifications
Product TypeJack to RCA Audio Cable
Connectors1x 3.5mm Male Jack to 2x Male RCA
Cable Conductor MaterialDual fine-stranded copper conductors (28 strands each)
ShieldingAluminum foil + braided copper shielding
InsulationPVC Jacket
Outer JacketNylon
Cable Outer Diameter6.5mm
Connector Contact MaterialGold-plated pure copper
Connector Body MaterialAnodized aluminum
Length1.2m
Packaging1x Fosi Audio 3.5mm Male Jack to 2x Male RCA Audio Cable
Length (m)1.2
ShieldingYes
Section (mm²)N/A
ConnectorJack 3.5mm
ConnectorRCA
FOSI AUDIO Interconnect Cable Male 3.5mm Jack to 2x Males RCA Shielded Copper 1.2m
The Fosi Audio 3.5mm male jack to 2x male RCA audio cable is designed to connect a source or device equipped with a 3.5mm jack output to equipment...
