SMSL PL200 MK2 CD Player ES9039Q2M
The SMSL PL200 MK2 is an audiophile CD player that also functions as a USB DAC, digital interface, headphone amplifier, and bidirectional Bluetooth transmitter/receiver.
By buying this product you get 61 loyalty points
Reference : 22239
619,00 €tax incl.
515,83 € tax excl.
Shipping date: 24-11-2026.
SMSL PL200 MK2 CD Player ES9039Q2M USB XMOS Bluetooth 5.1 AptX HD LDAC 32bit 768kHz DSD512 MQA-CD
SMSL PL200 MK2
The SMSL PL200 MK2 is an audiophile CD player that also functions as a USB DAC, digital interface, headphone amplifier, and bidirectional Bluetooth transmitter/receiver. It is equipped with an ESS ES9039Q2M DAC, an XMOS XU-316 USB interface supporting PCM streams up to 32bit / 768kHz, native DSD512, MQA, and MQA-CD playback. Its top-loading CD mechanism is paired with a magnetic CD clamp that minimizes vibrations to improve reading accuracy while also allowing playback with the lid open. Connectivity includes a USB-C input, optical and coaxial inputs, Bluetooth 5.1 reception and transmission supporting LDAC, aptX HD, aptX Adaptive, aptX, AAC, and SBC codecs, as well as RCA and balanced XLR analog outputs configurable as either Line Out or Preamplifier outputs. The headphone section features a proprietary PLFC amplifier circuit capable of delivering up to 2 x 1.5W into 16Ω, with both 6.35mm single-ended and 4.4mm balanced headphone outputs. The entire unit is housed in a robust CNC-machined aluminum chassis, complemented by a laminated IPS display protected by glass and a completely redesigned user interface.
SMSL PL200 MK2
SMSL PL200 MK2: ESS ES9039Q2M DAC and High-Resolution Playback
The PL200 MK2 features a latest-generation ESS ES9039Q2M DAC combined with an XMOS XU-316 USB interface to deliver outstanding digital-to-analog conversion quality. It supports PCM streams up to 32bit / 768kHz, native DSD512, DoP, as well as MQA and MQA-CD playback. Its ultra-low distortion level (THD+N of 0.00007%) ensures faithful, detailed, and transparent sound reproduction. A dedicated Transport mode also allows the analog circuitry to be disabled in order to reduce electromagnetic interference and optimize the quality of the optical and coaxial digital outputs when the unit is used solely as a CD transport.
SMSL PL200 MK2: High-Definition Bidirectional Bluetooth
The SMSL PL200 MK2 incorporates a Bluetooth 5.1 module that operates in both receiving and transmitting modes. In receiver mode, it enables wireless music streaming from a smartphone, tablet, or computer using LDAC, aptX HD, aptX Adaptive, aptX, AAC, and SBC codecs. In transmitter mode, it can send audio from a CD or USB source to compatible Bluetooth headphones or speakers, providing exceptional flexibility without compromising audio quality.
SMSL PL200 MK2: Powerful Headphone Amplifier and Configurable Analog Outputs
The PL200 MK2 features a headphone amplifier based on SMSL's proprietary PLFC circuit, capable of delivering up to 2 × 1.5W into 16Ω to efficiently drive a wide variety of headphones. It provides both a 6.35mm single-ended headphone output and a 4.4mm balanced headphone output. On the rear panel, the RCA and balanced XLR outputs can operate either at a fixed output level (Line Out) or with adjustable volume (Preamplifier mode), making integration equally easy in both traditional Hi-Fi systems and active desktop audio setups.
SMSL PL200 MK2 Overview
1CD Cover
2CD Clamp
3CD Placement Area
4Next
5Previous
64.4mm Balanced Headphone Output
73.5mm Headphone Output
8Stop
9Play
10Multifunction Knob
11Remote Control Receiver
12Operation Status LED
13Display
14Balanced XLR Output
15RCA Output
16Optical Toslink Output
17Coaxial SPDIF Output
18External Clock Input
19USB-C Input
20Bluetooth Antenna
21AC Power Input
Test of the SMSL PL200 MKII by Audio Science Review
"Like its predecessor: what a CD player! The MKII managed to perform a little better on measurements to reach the equivalent of analyzing the original WAV files in digital domain. Nothing more can be expected at this stage. Well done SMSL !
More than a high-end CD Player, it it the refence, what we will take for granted at this price point.
And it's not only a CD Player !"
Technical Specifications
Product TypeCD Player
DAC ChipES9039Q2M
USB InterfaceXMOS XU316
InputsCD
1x USB-C
Bluetooth
Outputs1x RCA
1x Balanced XLR
1x Coaxial SPDIF
1x Optical Toslink
1x 3.5mm Headphone Output
1x 4.4mm Balanced Headphone Output
THD+N0.000079% (-122dB)(UN-WTD)
Dynamic RangeXLR: 127dB
RCA: 124dB
SNRXLR: 127dB
RCA: 124dB
Headphone Output Power16Ω: 1.5W ×2
32Ω: 750mW ×2
150Ω: 160mW ×2
300Ω: 80mW ×2
600Ω: 40mW ×2
Headphone Amplifier GainLow Gain: +4dB
High Gain: +8dB
USB TransmissionAsynchronous USB 2.0
USB CompatibilityWindows 7 / 8 / 8.1 / 10 / 11 (with driver)
Mac OSX10.6, Linux (driverless)
Supported Sampling Rates32bit 768kHz, DSD512
Supported Bluetooth Codecs5.1 (SBC, AAC, aptX, aptX HD, LDAC)
Power Consumption10W
Standby Power Consumption< 0.5W
Dimensions200 x 47.9 x 175mm
Weight1.579kg
Package Contents1x SMSL PL200 MK2
1x Remote Control
The SMSL PL200 MK2 is an audiophile CD player that also functions as a USB DAC, digital interface, headphone amplifier, and bidirectional Bluetooth...
