FIIO DM15 CD Player Ripper DAC R2R Black
The FiiO DM15 R2R is a hybrid architecture CD player designed to combine stabilised playback mechanics, discrete R2R conversion and high-power amplification within a chassis designed for both portable and desktop use. Its internal design is based on an R2R DAC with discrete resistors, totalling 192 resistors selected for their precision and thermal stability, enabling continuous and consistent digital-to-analogue conversion, faithful to organic texture and analogue timbres.
By buying this product you get 26 loyalty points
Reference : 21402
269,00 €tax incl.
224,17 € tax excl.
FiiOo DM15 R2R CD Player Ripper DAC R2R on Battery 32 bit 384kHz DSD256 Black
Fiio DM15 R2R : Front view
Beyond CD playback, this approach extends to a USB-C DAC function capable of handling high-resolution streams up to 32bit 384kHz PCM and DSD256, while retaining the same R2R conversion chain. The integrated amplification, capable of delivering up to 2 × 1150mW under 32 ohms in desktop mode, allows for connection to a wide variety of headphones, while Bluetooth 5.4 connectivity based on a Qualcomm QCC3095 chip enables wireless streaming via aptX, aptX Adaptive, aptX HD and SBC codecs. This versatility is enhanced by differentiated power management, combining an internal battery for portable use and full bypass in a stationary configuration, making the DM15 R2R a CD player and DAC that fits naturally into everyday use.
FiiOo DM15 R2R : R2R DAC
The FiiOo DM15 R2R adopts an R2R conversion topology based on a discrete network of 192 resistors, organised into four independent channels of 48 resistors, enabling symmetrical and consistent conversion across the entire spectrum. These components are selected for a tolerance of 0.01% combined with a thermal drift limited to 30 ppm, ensuring electrical stability even during temperature variations associated with prolonged use. Beyond mathematical precision, this approach favours continuous signal reproduction, resulting in a dense and organic sound signature, directly inherited from traditional analogue architectures and particularly noticeable in timbres and dynamic micro-variations.
Fiio DM15 R2R : Diagram of the DAC R2R
Fiio DM15 R2R: Continuously improving servo architecture
This conversion approach is based on a servo architecture derived from the DM13, whose principle has been retained while undergoing targeted mechanical optimisations. The integration of a spring-mounted steel ball system improves disc stability during rotation, limiting micro-vibrations that can affect optical reading. At the same time, this mechanical solution maintains smooth kinematics, making CD insertion and removal more natural, which in practice translates into more stable playback without compromising everyday ergonomics.
Fiio DM15 R2R : CD fixing system
Fiio DM15 R2R : connected to a PC
FiiO DM15 R2R: DAC function
In order to fully exploit the capabilities of the R2R DAC beyond simple CD playback, the DM15 R2R incorporates a dedicated USB-C input, combined with a digital interface capable of handling high-resolution streams. This implementation allows support for PCM signals up to 32bit 384kHz as well as DSD256, while maintaining a processing chain consistent with the converter's discrete architecture. This versatility allows the DM15 to be used as a standalone DAC, both in a mobile context and in a high-resolution stationary configuration.
FiiO DM15 R2R: Bluetooth 5.4 function
Wireless connectivity is based on a Qualcomm QCC3095 chip, ensuring stable and energy-efficient Bluetooth 5.4 transmission. This platform supports aptX, aptX Adaptive, aptX HD and SBC codecs, allowing automatic adjustment of bitrate and latency depending on the source and listening context. This approach ensures continuity of use between local playback, wireless streaming and internal DAC operation, without introducing any functional disruption in the audio chain.
Fiio DM15 R2R : next to a telephone
Fiio DM15 R2R : Desktop Mode
FiiO DM15 R2R: Hybrid usage
The DM15 R2R adopts a hybrid usage logic, based on two clearly differentiated modes: portable and desktop. When on the move, power is supplied by a 4700mAh battery, offering approximately 7 hours of battery life, sufficient for extended listening sessions without the need for an external power source. In a stationary configuration, desktop mode bypasses the battery power supply, reducing thermal and electrical constraints while unleashing the full potential of the output stage, which delivers up to 1150mW + 1150mW under 32 ohms, allowing it to be paired with demanding headphones without compromising on dynamics.
FiiO DM15 R2R: Ripping CD
In addition to reading and conversion, the DM15 R2R includes CD ripping support via USB, allowing direct digital extraction of discs to an external device. This feature extends the player's use for archiving and digitisation purposes, while maintaining control over the optical playback chain. It is part of a comprehensive approach in which the DM15 is not limited to playback, but actively participates in the management and preservation of physical music libraries.
Fiio DM15 R2R : extraction de CD
Technical specifications
Product typeCD player
Ripper
DAC
InputsCD
1x USB-C
Outputs1x Mini-Toslink jack 3.5mm
1x Line output 4.4mm
1x Headphone output Jack 3.5mm
1x Headphone output Jack 4.4mm
1x USB-C (REC)
Bluetooth
ScreenLCD 0.96"
DACR2R
Amplification chips2x SGM8262
Adaptive impedance8~350Ω
Battery life~7h
Supported Bluetooth codecsSBC / aptX / aptX-HD / aptX-LL / aptX-Adaptive
Ripper function
CD mode headphone output specifications
Output power 3.5mm jack575mW+575mW @ 16Ω
315mW+315mW @ 32Ω
35mW+35mW @ 300Ω
Output power 4.4mm jack480mW+480mW @ 16Ω
1150mW+1150mW @ 32Ω
145mW+145mW @ 300Ω
Signal-to-noise ratio (SNR)Balanced: ≥ 112dB
Single-ended: ≥ 110dB
Dynamic range≥94dB
Frequency response20Hz ~ 20KHz (±1.5dB)
Output impedanceBalanced: < 1.5Ω
Single-ended: < 1Ω
Channel separationBalanced: ≥ 100dB
Single-ended: ≥ 72dB
Peak output voltageBalanced: 18.8Vp-p
Single-ended: 9.5Vp-p
Total harmonic distortion more noise (THD+N)Balanced: < 0.030% @ 1kHz
Single-ended: < 0.028% @ 1kHz
Background noiseBalanced: < 9.7µV
Single-ended: < 14µV
CD mode line output specifications
Total harmonic distortion more noise (THD+N)Balanced: < 0.029% @ 1kHz
Channel separationBalanced: ≥ 104dB
Single-ended: ≥ 100dB
Dynamic range≥ 94dB
Signal-to-noise ratio (SNR)110dB
Background noiseBalanced: < 18.4µV
Single-ended: < 9.6µV
Output levelBalanced: 6.5Vrms
Single-ended: 3.3Vrms
DAC mode headphone output specifications
315mW+315mW @ 32Ω
35mW+35mW @ 300Ω
1150mW+1150mW @ 32Ω
145mW+145mW @ 300Ω
Single-ended: ≥ 111dB
Dynamic rangeBalanced: ≥ 107dB
Single-ended: ≥ 106dB
Frequency response20Hz ~ 70kHz (±3dB)
Single-ended: < 1Ω
Total harmonic distortion more noise (THD+N)< 0.025% @ 1kHz
Background noiseBalanced: < 14.7µV
Single-ended: < 8.7µV
DAC mode line output specifications
Channel separationBalanced: ≥ 108dB
Frequency response20Hz ~ 80KHz (±2.9dB)
Background noiseBalanced: < 15.6µV
Single-ended: < 9.2µV
Power supply9V DC
Weight470g
Dimensions144 x 137 x 25.5mm
Package1x FiiO DM15 R2R
1x IR remote control
1x USB-A to USB-C cable
1x 3.5mm coaxial jack cable
InputCD
OutputUSB
OutputJack 4.4mm
OutputOptical Mini-Toslink
OutputJack 3.5mm
OutputBluetooth
DAC / ADC ChipR2R LADDER DAC
Max sampling rate384kHz
Max sampling rateDSD256
Remote ControlYes
Download
FIIO DM15 CD Player Ripper DAC R2R on Battery 32bit 384kHz DSD256 Black
The FiiO DM15 R2R is a hybrid architecture CD player designed to combine stabilised playback mechanics, discrete R2R conversion and high-power...
