By buying this product you get 31 loyalty points
The Shanling EC Zero T CD player retains the design and features of its big brother, the EC Zero T, but with new components and a much more affordable price tag. Its circuitry has been simplified and the tubes have been removed to make way for SGM8262 amplifiers. On the digital-to-analog conversion side, an AK4493 DAC chip now processes the signal. However, the exceptionally stable servo architecture, a robust battery offering up to 10 hours of battery life, and extensive connectivity offering numerous possibilities for use have been retained. In terms of aesthetics, the retro-futuristic design featuring numerous physical buttons and a volume slider remains. The sturdy tempered glass and aluminum chassis has also been retained.
1 | Stop |
2 | Play / Pause |
3 | Function selector |
4 | Previous track |
5 | Next track |
6 | Lock button |
7 | 4.4mm jack output |
8 | 3.5mm jack output |
9 | SPDIF Coaxial/Optical Output |
10 | Bluetooth antenna |
11 | USB-C DAC input |
12 | USB-C power port |
13 | Power mode switch |
Product type | CD player |
Chip | AK4493 |
Amplification | SGM8262 |
Input | 1x USB-C DAC input |
Outputs | 1x 3.5mm unbalanced headphone output 1x 4.4mm balanced headphone output 1x 3.5mm unbalanced line output 1x 4.4mm balanced line output 1x SPDIF coaxial/optical output Bluetooth |
Supported sample rate (USB DAC) | PCM 32bit 768kHz, DSD512 |
Bluetooth version | 5.3 |
Bluetooth transmission codecs | SBC, AAC, aptX, aptX Adaptative |
Screen | LCD 1.68" |
Output power | 525mW @ 32 ohm (battery) 840mW @ 32 ohm (USB powered) |
Battery life | Up to 10h |
Power supply | 5V 2A |
Dimensions | 158 x 150 x 28mm |
Weight | 669g |
Color | Gray |
Package | 1x Shanling EC Zero T 1x USB-A to USB-C cable |
