TRETTITRE TTT-DP3 Battery-Powered CD Player
The Trettitre TTT-DP3 is a portable CD player featuring Bluetooth 5.4 transmission, designed to combine physical media playback with wireless audio integration. Compatible with CD, CD-R and CD-RW discs, it relies on a compact design with a transparent magnetic lid, revealing the disc while making everyday use easier.
Reference : 22500
89,00 €tax incl.
74,17 € tax excl.
TRETTITRE TTT-DP3 Battery-Powered Bluetooth 5.4 CD Player
TRETTITRE TTT-DP3: Front view
Intended for both on-the-go listening and home installation, it combines a 3.5 mm jack output, an OLED display and a built-in 2000 mAh battery, allowing it to be used independently or with a headphone and a Bluetooth speaker. Designed to join the TTT-CP3 cassette player and the TTT-LP3 turntable, it can also take its place in a modular wall composition where the various audio formats contribute directly to the aesthetics of the installation.
Trettitre TTT-DP3: Portable Bluetooth CD Player
The Trettitre TTT-DP3 is a portable CD player that combines physical media playback with Bluetooth 5.4 audio transmission. Its transparent magnetic lid reinterprets the traditional design of CD players by keeping the disc partly visible while it spins, while its compact format allows it to be used in different rooms or carried easily.
TRETTITRE TTT-DP3: OLED screen
Trettitre TTT-DP3: Intuitive controls and OLED display
The controls feature raised tactile markers combined with a silver finish, allowing functions to be identified by touch and to pause or change tracks without looking directly at the device. This design is extended by a small OLED screen that displays the track number, playback status and battery level, keeping essential information immediately visible.
Trettitre TTT-DP3: Extended compatibility
Compatible with CD, CD-R and CD-RW discs, the TTT-DP3 also supports the CD-DA and HDCD audio formats. Its audio output on a 3.5 mm jack interface allows a wired connection to a headphone or an audio system, while Bluetooth enables pairing with compatible speakers and headphones, without needing a cable between the player and the diffuser.
TRETTITRE TTT-DP3: wireless connection
Trettitre TTT-DP3: Built-in battery
Powered by a 2000 mAh battery, the player operates independently after about 2.5 hours of charging. Its autonomy and its weight limited to 324 g make it easy to move between several rooms, for occasional listening or transport during a trip, while retaining a design suited to everyday use.
Trettitre TTT-DP3: Design wall mounting
The TTT-DP3 was designed to integrate into a wall composition bringing together the TTT-CP3 cassette player and the TTT-LP3 turntable. This combination creates a graphic and contemporary audio ensemble, where the various playback formats become an integral part of the décor while limiting floor space. The modular aluminum wall mount required for this configuration is supplied with the TTT-LP3 turntable.
TRETTITRE TTT-DP3 with TTT-CP3 cassette player and TTT-LP3 turntable, mounted on the wall
Technical specifications
Product typeCD Player
Outputs1x Jack 3.5mm
Bluetooth 5.4
SNR>70dB
ScreenOLED
Total harmonic distortion (THD)<3%
Battery2000mAh
Charging time2.5h
AutonomyJack 3.5mm output: 10h
Bluetooth output: 8h
Compatible disc formatCD-DA
HDCD
Compatible CD typeCD
CD-R
CD-RW
Supply voltage5V DC 2A
Dimensions170 x 170 x 27mm
Weight324g
ColorWhite
Package1x Trettitre TTT-DP3
The Trettitre TTT-DP3 is a portable CD player featuring Bluetooth 5.4 transmission, designed to combine physical media playback with wireless audio...
