By buying this product you get 383 loyalty points
The Shanling SCD3.3 is an SACD and CD-MQA compatible CD player featuring a third-generation discrete R2R conversion architecture developed in-house. It uses a 2R2 network totalling 212 resistors matched to 0.01%, spread across four channels to provide 24-bit conversion.
This conversion base is built around segmented clock management, with two independent sets of oscillators, allowing the digital processing domains to be separated and limiting jitter interactions. Analogue shaping is based on an OPA1612 providing low-pass filtering after the R2R DAC, extended by a MUSES8920E configured as a buffer to stabilise the output impedance, while a pair of 12AT7 tubes introduces a controlled analogue harmonic signature.
The Shanling SCD3.3 is an SACD and CD-MQA compatible CD player, designed to play high-definition discs and act as an external DAC. It centralises the management of physical discs while allowing the use of dematerialised digital sources, enabling it to occupy a central position within a Hi-Fi system.
The SCD3.3 incorporates the third generation of Shanling's in-house developed 2R2 DAC, based on a fully discrete topology. The unit features a total of 212 0.01% matched resistors, spread across four channels to provide 24-bit conversion.
In this architecture, 19 bits are dedicated to the actual conversion, while 4 bits compensate for residual errors and 1 bit drives a differential push-pull circuit, balancing the positive and negative alternations of the signal. This hierarchical distribution optimises low-level accuracy while stabilising dynamic behaviour.
Beyond the R2R network, the analogue section adopts a progressive approach: an OPA1612 provides low-pass filtering at the conversion output, attenuating spectral images related to sampling and limiting intermodulation in subsequent stages. This shaping is extended by a MUSES8920E used as a buffer, ensuring stable impedance matching and controlled current capacity, thus enabling the amplification stage to be powered without signal degradation.
Temporal consistency relies on two independent sets of oscillators: 90/98 MHz dedicated to the FPGA, and 45/49 MHz reserved for the XMOS section. This separation of clock domains helps to keep jitter under control when processing external streams.
The output section incorporates a pair of 12AT7 tubes to directly influence the final sound signature. This topology does not aim to structurally modify the frequency response, but rather introduces a typically analogue harmonic colouration.
This approach combines the temporal precision of the R2R DAC with a more organic texture, while maintaining the electrical stability provided by the upstream stages.
The 9.5 mm thick CNC-machined aluminium chassis provides structural rigidity, limiting vibrations that could affect the playback mechanism. The CD tray on the top optimises accessibility and simplifies use, while the transparent opening reveals the tubes.
The interface is based on a 5-inch touchscreen, complemented by compatibility with the Eddict Player application available on Android and iOS, allowing remote control of the device.
| 1 | Power button |
| 2 | Power input |
| 3 | Fuse |
| 4 | Bluetooth antenna |
| 5 | USB audio output |
| 6 | I2S digital output |
| 7 | Sortie coaxiale |
| 8 | Entrée DAC USB |
| 9 | Entrée coaxiale |
| 10 | Sortie XLR symétrique |
| 11 | Sortie RCA asymétrique |
| Specifications | |
| Product type | CD player DAC |
| Inputs | CD player 1x USB-A 1x USB-B 1x Coaxial Bluetooth 5.0 |
| Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR 1x USB-A 1x HDMI I2S 1x Coaxial |
| Processor | Ingenic X2000 |
| DAC | R2R 24 bit |
| Screen | 5" touch screen |
| Controls | Front buttons Remote control Mobile app |
| USB Supported formats | DSD / DXD / APE / FLAC / WAV / AIFF / ALF / DTS / MP3 / WMA / ACC / OGG / ALAC / MP2 / M4P / AC3 / M3U / M3U8 / OPUS |
| Supported Bluetooth codecs | LDAC / aptX HD / aptX / AAC / SBC |
| Output level | XLR: 4.9Vrms RCA: 2.4Vrms |
| Frequency response | 20Hz-40kHz |
| Total harmonic distortion more noise (THD+N) | 0.15% |
| Crosstalk | 110dB |
| Dynamic range | 117dB |
| Signal-to-noise ratio (SNR) | 117dB |
| Supported sampling rates | PCM up to 32bit 768kHz DSD up to DSD512 |
| General | |
| Power supply voltage | 220V AC |
| Dimensions | 430 x 319 x 91mm |
| Housing material | Aluminum |
| Weight | 10kg |
| Color | Silver |
| Package | 1x Shanling SCD3.3 1x Power cable 1x Bluetooth antenna 1x Remote control |
| Input | Bluetooth |
| Input | SPDIF |
| Input | CD |
| Input | USB |
| Output | USB |
| Output | I2S LVDS via HDMI |
| Output | Coaxial SPDIF |
| Output | RCA |
| Output | XLR |
| DAC / ADC Chip | R2R LADDER DAC |
| Color | Silver |
| Networking | No |
| Remote Control | Control app |
| Remote Control | Yes |
