SMSL PL100 PRO CD Player Silver
The SMSL PL100 Pro, an evolution of the PL100, is a CD player now based on two CS43131 DAC chips combined with a PLL (Phase-Locked Loop) circuit to provide sound reproduction as close as possible to the original source. The unit supports several CD formats: CD / CD-R / CD-RW / MP3 CD.
Reference : 21587
159,00 €tax incl.
132,50 € tax excl.
SMSL PL100 Pro CD Player 2x CS43131 Silver
Photo of the SMSL PL100 Pro
The SMSL PL100 Pro, an evolution of the PL100, is a CD player now based on two CS43131 DAC chips combined with a PLL (Phase-Locked Loop) circuit to provide sound reproduction as close as possible to the original source. The unit supports several CD formats: CD / CD-R / CD-RW / MP3 CD. It also features multiple outputs including a coaxial output, an optical Toslink output, an RCA output and a balanced XLR output. In addition, it includes a 3.5mm headphone output and a balanced 4.4mm headphone output capable of delivering up to 2x200mW at 32 Ohm for a high level of compatibility. The PL100 Pro retains the form factor of its predecessor and also features a display, several control buttons and a remote control for full remote operation.
SMSL PL100 Pro: 2x CS43131 DAC Chip
The CS43131 DAC chips, combined with the PLL circuit, provide high-quality CD decoding for a final sound reproduction with excellent transparency. Indeed, the PLL circuit significantly reduces jitter during playback while the two DAC chips ensure symmetrical signal processing.
SMSL PL100 Pro: Raw digital outputs
SMSL PL100 Pro: Raw Digital Outputs
The coaxial output and the optical Toslink output of the PL100 PRO are capable of delivering the raw signal for a direct connection to a DAC in order to achieve the best possible sound quality.
SMSL PL100 Pro: 3.5mm and 4.4mm Headphone Outputs
Thanks to its CS43131 DAC chips, the SMSL PL100 Pro CD player is also capable of delivering up to 2x200mW at 32 Ohm through its balanced 4.4mm output, allowing it to drive a wide range of headphones and earphones.
SMSL PL100 Pro: Flexible installation
SMSL PL100 Pro: Flexible Installation
The form factor of the SMSL PL100 Pro CD player allows it to be positioned either horizontally or vertically.
SMSL PL100 Pro Overview
SMSL PL100 Pro overview
1Disc slot
2Display
3IR remote receiver
4Control buttons
5Balanced XLR output
6Balanced 4.4mm headphone output
73.5mm headphone output
8RCA output
9SPDIF Coaxial output
10Optical Toslink output
11USB-C power port
This device does not work with USB-PD (Power Delivery) power supplies. Please use a 5V 3A power supply.
Technical specifications
Product typeCD Player
DAC chip2x CS43131
InputCD
Output1x Coaxial output
1x Optical Toslink output
1x Single-ended stereo RCA output
1x Balanced stereo XLR output
1x Single-ended 3.5mm headphone output
1x Balanced 4.4mm headphone output
Supported CD formatsCD / CD-R / CR-RW / MP3 CD
Output levelRCA: 2Vrms
XLR: 4Vrms
THD+N0.001%
SNR110dB
Headphone output power
Balanced 4.4mm100mw @ 16Ω
200mw @ 32Ω
160mw @ 64Ω
85mw @ 150Ω
53mw @ 300Ω
25mw @ 600Ω
Single-ended 3.5mm58mw @ 16Ω
58mw @ 32Ω
45mw @ 64Ω
23mw @ 150Ω
12mw @ 300Ω
6mw @ 600Ω
Power consumption4W
Standby consumption< 0.1W
Dimensions160 x 44.5 x 160mm
Weight953.5g
ColorSilver
Package contents1x SMSL PL100 Pro
1x USB-A to USB-C power cable
1x Remote control
SMSL PL100 PRO CD Player 2x CS43131 MQA Silver
The SMSL PL100 Pro, an evolution of the PL100, is a CD player now based on two CS43131 DAC chips combined with a PLL (Phase-Locked Loop) circuit to...
